My first car had that gear pattern except it was on the floor. 1931 Model A Ford!!
Mine had that same air conditioner too! Mine also had an auxiliary starter under the seat. It was called a crank!! All you had to do was to retard the timing with the lever on the left side of the steering column and go to the front and give it all you had. Lots of fun!!Mine was a '39 Ford.
On the floor.
Same pattern.
Air conditioning via a crank that opened the windshield 3" at the bottom.
I had a crank handle under the seat. Get out, poke it into the front grill and crank. Frankly it was easier to just push it a bit and pop the clutch.Mine had that same air conditioner too! Mine also had an auxiliary starter under the seat. It was called a crank!! All you had to do was to retard the timing with the lever on the left side of the steering column and go to the front and give it all you had. Lots of fun!!
Overdrive was cool. After you started in first gear, you could shift into second and high without using the clutch.And later there was overdrive too.
Who used the clutch after first gear?Overdrive was cool. After you started in first gear, you could shift into second and high without using the clutch.
Never tried the no clutch option. First I've ever heard of that. Seems like you'd be tearing up some gears without the clutch.Who used the clutch after first gear?
I didn't.
Drove my dad crazy
I called synchronization. Clutch to first gear yes.Never tried the no clutch option. First I've ever heard of that. Seems like you'd be tearing up some gears without the clutch.
Yep. Regular Girl with a huge voice. I think she was a member of the “27 club”.Is that Janis???
