My Furnace hasn't stopped for two days now.
House is at 66 Degrees F
If I get any closer to the fireplace, I'll need BBQ sauce on my navel.
I have 2 fireplaces. They totally suck at keeping the place warm as in the natural state of a fireplace, since 90 percent of the heat goes up the chimney.My Furnace hasn't stopped for two days now.
The original Fireplace in my house was the standard firebox. When I moved it, yes, the box flue and chimney the whole friggin mess. I reused the old one. Big Mistake.I have 2 fireplaces. They totally suck at keeping the place warm as in the natural state of a fireplace, since 90 percent of the heat goes up the chimney.
I put wood stove inserts in both. It's zero degrees with -30 or more (worse) wind chill. The wood stoves are keeping the place toasty.
Does it cost a lot more to keep feeding it pellets instead of wood? I know the pellets are made of wood so I suppose the chimney needs cleaned same as with wood. Right?Good wood burning appliances are crazy expensive. My Harman Pellet stove has doubled in price in 15 years. My model now costs over 5 grand to replace!!! I swallowed hard in 2008 when I dropped $2499.00 on that old girl but it was one of my smartest decisions. The best part is you can keep them running forever as they are easy to service and all one needs to know about it is on YouTube. I have kept a spare auger feed motor on hand just in case for years now and so far never needed it. It literally takes longer to get the tools rounded up to do the job than it does to do it.![]()
OK, been running the wood stoves for a couple days now. Nobody is up at night to keep them loaded so it was a bit chilly this morning. Just about out of wood inside and I just don't feel like bundling up and going outside to get more right now.It's zero degrees with -30 or more (worse) wind chill. The wood stoves are keeping the place toasty.
Could be a squirrel in the attic lunching on the wiring.4 Degrees (F) here and under a winter storm warning from the National Weather Service. -22(F) wind chill. Trees are swaying in the wind, wind chimes have been clanging for 3 days. So we still have a bit of a breeze out there.
Furnace is working. And it worked all night too. So we got lucky.
But now I have a fuse blown in my family room, storage room and reading nook. Not sure why, nothing is currently plugged into any of the outlets. Breaker may have gone bad? Or something else is shorting it out. I click the breaker and it immediately trips.
One thing that very high winds, combined with -10(F) degree temperatures showed me is how piss poorly some of my windows seal. Going to be looking at installing new weather stripping in a bunch of the windows as soon as the temperatures moderate a bit.
Bob,One thing that very high winds, combined with -10(F) degree temperatures showed me is how piss poorly some of my windows seal. Going to be looking at installing new weather stripping in a bunch of the windows as soon as the temperatures moderate a bit.
Oh my. Are you going to be able to peal that duct tape off without damage to finishes or leaving the gummy part of the tape behind? Not as thick but I just use painters tape.Weather stripping? I had none on hand but found, and consumed, an entire roll of duct tape sealing doors and windows over the last two days.
No wiring up there that is not inside conduit. So not squirrels.Could be a squirrel in the attic lunching on the wiring.
