Snowy Rivers
Busy day today....but productive too.....
The Kids came up and grabbed the faithful little Scat Trak and loaded the Dirt bike rack on the Big Dog..
I was busy putting the finishing touches on the Body lifting rig so the Family model can be lifted into place on the cat....
The lift rig is the same unit I used to get the standard cab up into place on the cat.
Added a truss over the lengthwise tubes to handle the extra weight of the family model.
The center beam can be slid back and forth a lot to get the balance point spot on....Once in place the set screw is tightened.
The truss king pin has two threaded rods to allow the center beam to pass under the truss and then spacers are slipped under the threaded rods and the rods snugged up.....Sort of a McGyver....(Rube Goldberg) But it should work fine.....
Not real sure that the truss was totally necessary ....But I really do not want to have the lift go south just as the body is going up onto the CAT CHASSIS....That would SUCK....
The rig is really basic and not pretty....Added materials from what was in the short stock rack and a couple pieces of 3/16 x 1 inch flat bar new materials....
Just want it simple and strong....we will need it to place the body as well as remove it for some service work in the future....
If all goes well....May go for a test lift tomorrow and get a feel for things.....
I need to carry the family model out of it's current location and turn it around.....
Need to remove the single cab and get it out of the way....
Then the family model can be placed on the cat chassis. For the time being on wood blocks until the radiator location and height can be sorted out.
Going to modify the A pillar body mount to gain elevation and then fabricate the other mounts to fit exactly where they need to be......The A pillar mount was a bit involved with other parts....NOT GOING TO HACK IT UP....
I came across some 17 gallon fuel tanks today that come with the filler neck/cap...The fuel outlet and vent fittings....
These bad boys will fit perfectly in the rear wheel house area....Will need a little bit of fabrication to add mounting brackets to the cat chassis.
The tanks come with the 0-90 ohm gauge sending unit (Standard for the GM dash gauges of this time frame)
Pretty much a plug and play...
That's about it for today....
