Had a great day...got a fair bit of work done too.
Slow slog on several of the lower fender bolts.
LOTS OF SKUNK PIZZ AND PATIENCE TO REMOVE A FEW BOLTS WITHOUT BREAKING THEM...
Both fenders removed.
The core support was slightly damaged butttttttttttttttttttttttt.....quite easy to straighten up.
The body is in great shape with little to no rust.
I need to get the skunk pizz on the cab bolts asap and let it soak a bit so they will come loose.
May even be able to use the mounts ??????? we shall see....
Carefully removing all the wiring for the lighting off the front end....
Once the cab is on the cat....the wiring can be massaged to length to allow all the factory lighting to function as it did when new back in 1993.
The wiring looks great as do the plugs.
All the engine wiring needs to come loose to allow it to conmnect on the cat.
Using all the S10 sensors will make life easy and the dash gauges should work.....
The speedo is likely not going to be worth messing with.......
Fuel gauge on the early GM rigs is 0-90 ohms and with any luck the original setup that was in the 2100 can be replaced with a sender that will get the dash gauge operational.....
Temp gauge is a simple type sender with a single plug
The oil pressure switch is a tad more complicated....but the factory sender will work.
The original sending unit has the pressure sender and 12v feed for the in tank fuel pump.
The feed to the electric pump can be terminated and abandoned at the harness where it fed the fuel pump... Simply cut and tape up the unwanted wires.
The 305 Chevy in the cat has a mechanical pump on the block.....this will be used as the supply pump....May add an electric pump as a primer pump.
Getting all the wiring off the engine and bundled up so it can be sorted out and routed to the 305 in the cat will require a bit of patience.
Same goes for the frame wiring that feeds the rear lights .
My intent is to have 100% of the factory lighting connected.....
The rear lamps will likely be the type used in heavy commercial trucks......
These are cheap and work well.....
If memory serves...we have a plastic tub of new lights on a shelf in the basement left from my trucking days....these new lights need a job....
In looking over the air plenum in the cowl after removing all the sheet metal and grille work and the wipers....lots of pine needles and junk.
Great time to get the heater fan out and clean the area up.
All in all this cab is in great shape.....
I was worried about rot/rust.
The truck appears to have come from a dry place with pine trees.....
Definitely getting exited about getting the cab off the chassis and being able to start designing the mounting hardware.
Should be really simple based on how the cab sits on the frame now.....
A pair of box tube cross members should do the trick really well.
Reuse the factory cab mounting holes and the rubber mounts (May need new rubbers)
