Blackfoot Tucker
This update could be called “WBJ1 Hides an Easter Egg... Years in Advance”.
Mrs. Blackfoot would tell you I lack patience, and she’s right. If I decide to play a joke on someone, it’s a pretty short term thing, so WBJ1 deserves great credit for his patience while waiting for his "Easter Egg" to be found. Here’s the story:
Readers will recall WBJ1 sent us a “mystery engine” that turned out to be a GM L94 LS series engine, though to this day we don’t know what year it is, or what it was originally installed in. I know they were used in the Cadillac Escalade, so I’m going with that as the original vehicle.
The engine as delivered.
We really haven’t messed with the engine at all. We did have to replace some damaged coil packs, and we replaced the spark plugs. The oil filter was dented and we replaced that and we drained the engine oil. We added exhaust manifolds, as there were none with the engine. But other than installing a new harmonic balancer and some minor front of the engine modifications it’s basically as we received it. Part of the process of getting P-Z ready to start involved adding anti-freeze, transmission fluid, and of course engine oil. We started by adding five quarts of full synthetic oil and checked the dipstick. Nothing... bone dry. We added more oil. Still nothing... and still bone dry.
Hmmmm? And especially with a new oil filter we should see oil on the dipstick. Where is this oil going? There’s no puddle of oil on the floor, so there’s no massive leak. But something is amiss…
I look at the dipstick and there is a stamped number on it. Here’s a pic of that number.
As the saying goes, “Google is your friend”, so I Googled “GM 12577660” and presto, a GM parts website comes up and provided this information:
WBJ1 sent us an engine with a shorter dipstick from a completely different engine family! (At least it was shorter and not longer.)
“Sweet” WBJ1? I don’t think so...
I've ordered a dipstick for a 2009 Escalade with a 6.2L engine. I THINK that will be correct, and the Easter Egg episode will be over.
We did try and start the engine and perhaps not unexpectedly, there are issues. As a late model engine, it has an OBD II port and the check engine light is on. Reading the codes shows oxygen sensor issues, which is to be expected because none are presently installed, and there are codes relating to the throttle pedal position sensor circuit e voltage being low. Basically the gas pedal assembly isn’t working, so depressing the pedal does nothing. It did start, sort-of. It will run for 5-10 seconds but only on two or three cylinders. At this point we think the fuel injectors are likely clogged as they sat for years and years and the fuel in the system dried up and left deposits.
We've removed the fuel rail and the fuel injectors and cleaned them as best we could. We reinstalled them in the fuel rail and filled the fuel rail with SeaFoam; hoping that will free up the injectors.The fuel rail and injectors are soaking for a few days. New fuel injector O-rings are on order as well as a new throttle pedal position sensor, which is basically the complete pedal assembly. I say this very rarely, but I was pleasantly surprised how reasonably priced it was..
More slow progress, but still moving in the right direction and we’re a little closer to completion...
