Imp with leaf springs vs torsion axle
Great pictures of the truss plates, definitely worth a thousand words each.
I should probably correct any misconceptions about me so I am not put in the expert category, but I will rely on your ability to take any suggestions for their value alone.
What I intended to do for alignment was to run a piano wire or string line in a loop aroung the drive sprockets and idlers to line up the bogies.
I would suggest you think carefully about how you weld the truss plates to the 2" square tubes on the Imp frame. Welds inline with the square tubes may have less negative impact on strength than perpindicular welds. Welds on the vertical faces of the tubes may have more impact on strength than welds on the top and bottom of the tubes, mostly because one would expect more vertical forces on the tubes than lateral forces.
If you look at a truck frame, you will typically not see any welds on the vertical members, the same is true for the I-beams of cranes, because the major forces are vertical and all the strength of the vertical member is desired. With a few horizontal gussets you could spread the weld over a longer area, and use skip welds to allow for more flexing.
Two major sources of concern for breakage are: catastrophic failure, for instance from shock; and long-term fatigue, say from repeated flexing.
Intuitively, the same two wheels are attached to the square tube, so unless the torsion suspension is stiffer or you plan on operating more heavily loaded and/or hitting bumps harder, then you would not expect more force to be transmitted into the existing tube.
When it comes to long term fatigue, if there is too much weld concentrated in a small area next to a flexible member, then right at the edge of the weld where stiff meets flexible, it is common to have failure. This phenomenon is very common in welded hydraulic plumbing that is flexing, pin hole leaks develop in the welds from mechanical fatigue.
That is the reason why I had opted for a sub-frame, to spread the load out over a larger area. It also allows all the torsion half-axles to be mounted in a trailing arm configuration. In a leading arm configuration you may have to be concerned with the possibility that the geometry allows you to hit a bump with the force inline with the trailing arm, not rotating the torsion arm but transferring all or most of the energy into the frame.
As far as clearance goes, it is hard to tell if what you have will clear. If I understand where your concern is about clearance, what some suspension systems incorporate is additional idlers to keep the top of the track from hitting anything, they might be more efficient than a skid plate.
Mtncrawler brought up a really good point about having the bogie wheels too much lower than stock, you could likely develop a lot more rocking chair motion from the shorter contact area with the snow, I can just envision those snowmobile moguls on a hard packed road, might need some Dramamine.
When it comes to 1/4" versus 3/8" thick, my instinct is that 3/8" would be very stiff and that you probably need to retain some flexibility. I would be most concerned about the part of the existing 2" square tube between the inside truss plate and the 18" wide tunnel of the Imp. That section is very short, will now be very stiff. That might mean that long-term fatigue is more of an issue than catastrophic failure.
I would think the 700# times eight torsion axles would be enough if your machine is around 3000#, but you might want to talk to Flexiride, they were very helpful before when I called them. Where they told me they have run into trouble is with double and triple axle trailers where the load that an individual axle encounters is much higher than one would imagine. I was told that typically the horizontal torsion axle snaps off. Here you have a quad axle vehicle, so in the wrong conditions you can get a lot of force on one bogie.
Ouch! Alaska Spring in Anchorage made eight new ones for me at about $32.00 each! Yeah, I bet he would love to sell you some!!! Heck, so would I......
I bought replacement springs for my IMP from a business in Fairbanks last year for a $100 ea. They look good. Im sure he would love to sell you some. Jim @ tracer 907/456-7278
Are you guys familiar with nuttsters post on this subject? He did the best job I have ever seen done on this mod on a 1402. It looks bulletproof.
Thank you Bulldog1401, after reading more carefully through the related topics in the forum I did find posts by nutsster.
I am not sure why I did not think of making a separate frame for the torsion suspension like nutsster did.
I really did not want to cross that point of no return by welding on the existing frame.
A separate sub-frame bolted onto the Imp will be a much better option for me.
I am also considering adding a front sliding member and track tension cylinder like my Super Imp has.
Please show me what you come up with . I am interested in adding something to the front idler that will allow it to give a little upon impact without bending the frame and yet keep the track tight.
Bulldog1401, have you had any problem bending the frame, or are you wanting to prepare?
I envision you being worried about hitting a snow covered stump, at which point I would be concerned about grouser damage and other problems even with some give.
Here is a screen capture of my start on a torsion sub-frame. If I did not already have the torsion half-axles I would definitely be working on a design with full torsion axles like nutsster used.
If you can tell from this rendering, at this time I am showing a telescoping section to adjust the front idler and if I use a cylinder to pump grease in to extend like the Super Imp, it would not help in the event of a collision.
I'm working on a Bombardier SV200 and the chassis looks very much like what you've pictured. Perhaps my primary information source from the forum, "boggie", would have some advice.
Hi Snowbird, I looked at your posts on the Bombardier SV200 project, and your torsion half-axles are very similar. I see nothing lifts like a deer!
Imp, does your idler mount look like the one in this rendering?
If a lot of Imps are the same dimensions here, then perhaps there would be a benefit if I designed a bolt-on track tensioner.
How about a bolt on front torsion axle with tension adjustment capabilities??
I'll offer to laser cut mounting stock for several sets in my shop if someone designs it. I was thinking of going with a 12" rim front idler wheel and have the front axle torsion arms facing almost straight back to avoid sever track tension fluctuation's.
A LMC 1500 front axle is a great example of what I was thinking of. I believe mtntopper has a schematic of the suspension on his.
I hope these parts diagrams help. You can also call Peterson's in Logan and see if they would provide the engineering drawings of the axle suspension system for you.
1200 LMC With Hydraulic Track Adjuster
1500 LMC With Manual Adjusting Threaded Rod
I have had several private emails with questions about the torsion axles that I installed on my Imp 1402. I have operated it for two winters now and it is a huge improvement in ride and performance over the stock leaf spings. I am cofident that it will out perform any Imp in deep snow or on rough terrain. :pirate: I will try to get some new photos to help people considering this mod and post them as soon as I can.
If I was to do this mod to an Imp today, I would go to four torsion axles (wheels) and get rid of the front idler. I would also move the differential strait back about 24" and go to the smaller "Super Imp" sprockets. This would completely raise the drive sprocket and differential up for more clearance and would reduce the work load on the OC-4 rear end. ( It would turn much easier with the smaller drive sprockets.)
It would end up looking like a late model 1200 sprite. The front axle would then be used to adjust track tension with either hydraulic cylinders or a manual nut and bolt set-up.
This would help with the problems of the Imp which are; clearance, ride and turning performance. It would also increase the foot print a bit and make it even better in the deep snow.:thumb:
On the Super imp they have incredible turning abilities for a gear driven cat. I associate this with the smaller rear drive sprocket. I do notice though that they are a fast machine but might not have the low end torque for long hill climbs with out kicking down into a lower gear creating possible track spin which would halt your forward movement. Even though they do have the smaller sprocket they still dont have alot of ground clearance. If you want more clearance then youll need taller boggies or drop down axles. I would opt for taller boggies and a rear sprocket somewhere between an Imp and Super Imp size. Maybe a 1200 spryte sprocket?
Teeoster, I looked at Dexter torsion axle dimensions, and as pointed out by others, with the standard size Imp tires 4.80-8 (16" outside diameter) the axle will be hanging down in the way, which you can see in the attachment.
If you are going to be using the torsion half-axles you have and if it would help you, I would be happy to help provide some designs for you.
I am going to continue designing with the torsion half-axles I have for my Imp, but I do not think that modification will be the same for anyone else.
My torsion half-axles are short enough that they will be inside the track out of the way.
If anyone is interested in using the free program SketchUp by Google that I have been using for 3D design, it is very easy, and if there is anything else I can do to help, just let me know.
You need to forget the small Imp tires. I went to the 16" diameter tires to smooth out the ride over the grousers. Also, it is good to turn the front torsion axle forward as you have done to reduce track slack during compression ( the same as other snowcats ) Performance of the axle is the same forward or backward due to the slow speed that they travel.
I also believe that the Imp 1404 has too little power for the high gear ratios that it has. They are usually operated in the lowest gears, particularly in deep snow. It is also capable of much higher speeds than almost any other cat. The smaller drive sprocket would bring the speed down as well, giving the 1404 more power to the track and place the best gears ratios in the middle of its gear selection. Torsion axles can be made indiviually or in any width and angle desired to meet the application.
I bid on the Super Imp that Bill at snow trans purchased from Colorado with hopes of converting it to torsion axles like a LMC 1500. I am confident that adding some more track area combined with torsion axles would make it an incredible performer. I would make 36" or 40" symetrical tracks for it too.
Someday I will find one at a good price and modify it to this configuration. :thumb:
Thank you nutsster for the advice, it is great to benefit from what you have actually experienced rather than to rely on what seems logical.
Can you tell me the tire size you used and does it match the profile of the standard Imp tire guides?
My hubs are 5 lug on 4.5" bolt circle, so I may be able to use similar wheels and tires.
Here is one idea for a bolt-on Imp adjustable idler mount.
The mount pictured provides about 6" of adjustment, but there appears to be plenty of room for more.
Any comments would be appreciated.
If anyone is interested, I would be glad to provide dimensions and/or the SketchUp file.
Nice Job! I was just looking at the front axle on mine last night. I think your right on with the concept., use as much existing structure as possible. Going with a completely new front axle does present allot of issues in itself, that may or may not be worth the work and cost involved. If you can send me a PM with your sketch file, I have downloaded the program but have no clue how to use it yet.
I like your drawings and design. Your design is very similar to my track adjustment set up. My 1402 didn't have any forward idler adjustment, so I made a plate like your drawing only on a horizontal plane not veritical. You will run into problems with the larger wheels if you don't chop off the leaf spring axles.
I know that your trying to be able to go back to the orginal configuration if it fails to work. Just carefully plan it all out and make it happen. Like I said earlier, I would consider removing the forward idler and move the front torsion axle forward and make it adjustable. However, that's your choice and would make it a little more complicated if your trying to use the orginal tracks.
Another important thing if you go to the taller tires is that your going to need to raise the whole chassis. This will give you a few more inches of ground clearance too. The problem will be the need to lower the differential a few inches to match it up with the torsion axles. That is why I think it would be great to just move the differential back a foot and a half and go to the smaller sprockets. That would eliminate the need to lower the differential. I will need to check this weekend which tire size I used when I go up to the cabin. They do fit nicely in the guides of the grousers.
I gathered up all the componets and actually used them in place to check for clearances and geometry. Your drawings can help you a lot in this area too.
My 1402 was modified so much before I got it that I had no choice but to do what I did to it. It wasn't working real well the way it was butchered.
The rear differential was already lowered somewhat, but not well done. I had to drop the rear of it and angle it down ward to get it where I needed it. I'll try to get some pics of it for you to see.
I am very happy with it and the way it runs now. It is nothing like an Imp in ride or performance now. It's MUCH better! :thumb:
Has anyone done any more work on thier Imp suspensions ?
I need to get new wheels, tires, belts and sprockets and before I knock myself out at making it stock, I'd like to think some more about changing to a torsion suspension.
Thanks
The Super Imp Wide Track loaded down with 1,500 lbs of gear and two adults pluse 60 gallons of fuel performed beuatfully in the field for me. The floatation was great (Over 500 miles of unbrocken trails and deep powder in the last 5 weeks!)! If I was going to use it again I would go with the same setup but with an enclosed rear cabin to keep our gear out of the weather, but I think its still a bit small for me and all our gear. Now that the rims are getting a bit difficult to find (suspect BOGGIE will start stocking the parts after he gets them made) I would also go to a torsion axle setup just to have a common rim available. BUT as I said that may not be an issue much longer. The Super Imp would indeed be a force to reckon with if someone put some wider tracks on. BUT really I dont think there is much need if you keep the weight down to what I would normally carry into a cabin. I think right now the Super Imp Wide Track is probably the best cabin access cat one can get right now. As far as an IMP I believe the Torsion axle set-up makes good sense. I found and old Imp with no tracks (see pictures) that I think will be a great contender for the torsion set-up. I also found a brand new never used military Ford V4 Wisconson engine still in the crate and also the one in the Imp was rebuilt. I may sell the engines if anyone is interested. Anyway I would like to do a torsion setup on this little Imp along with maybe an engine swap?
Are you pushing the diff straight back to wrap more track around the drive sprokets? Also what are the part numbers of the torsion axles you used. I have a 1401 imp and believe that they would be of similar weight. Thanks.
I like the idea of moving the rear diff back. I would like to find an OC-12 for the cat pictured above. I would make it my extreme powder cat! A light weight Imp body with 8'6" of tracks and a small Imp Body? Man what a combo that would be! Maybe a Chevy 4.6 V6 aluminum block and heads with an automatic mated to an OC-12?
Heres the last photos. Hope this is the place to dream up a wide track torsion axle project!
I would go with a hydraulic set-up like found on my Super Imp. Its a hyrdraulic cylder in the frame the the base is attached to the leading boggie. As you pump grease in the cylinder expands and the boggie moves forward. To release the pressure you remove the zirk fitting. I am sure you could design a simple release valve rather than unscrewing the zirk. Also a better position of the zirk for easier access would also be desirable. Just my opinion.
The shifters on this imp are nearly in line, laterlaly. Mine are in line fore and aft. What is the difference? Thanks.
Looks like quite a project, sad to see the Imp got to than level of neglect. You got your work cut out! Good luck!
The 4.80 x 8" and 4.80 x 12" wheels I have found for trailers are 3.75" wide bead-to-bead.
The integral hub 8" wheels on my Imp and Super Imp are 2.5" wide bead-to-bead.
The same 4.80 x 8" load range C tire on a trailer tire (3.75" wide) inflates to 5" wide and will touch the springs on both sides unless they are moved apart.
You may be able to tell from these pictures that the tire guides are also very close to the rim with the wider wheels which makes them much more vulnerable when travelling on side hills or when the tracks are not flat on the ground.
Has anyone had experience using the standard 3.75" wide trailer wheels with the standard Imp or Super Imp tire guides?
Yes I do. I just installed one. What I have found is that you cannot use a regular inner tube. The sides of the inner tube get what looks like a snake bite. The "bite" is what happens when the track guide rolls into the side of the tire on any type of side hill use or when your moving at a good bit of speed and the tire compresses. This will result in a flat tire. On the fatter tires they really need to be foam filled to avoid flats.
