I
Intake and exhaust manifolds installed.
Procedure for installation is to gently snug the Intake to exhaust manifold bolts after applying antisieze to the shanks and threads. This allows the flanges on the block to align first.
Install the manifolds on the block then slowly tighten the nuts from center out slowly in many steps to 20 ft/lbs.
Then tighten the intake to exhaust manifolds slowly in many steps to 25 ft/lbs.
You can certainly see how much these manifolds suck in and conform under load.
Cast is a blast!
View attachment 195670View attachment 195671View attachment 195672View attachment 195673View attachment 195674
I don't get it Brian. Why didn't you replace that flat head with an LS engine as all Tucker restorations should have? Think of the time you would save.
I
yup was tough not to slap a turbo and sniper fuel injection on this one.
resto mods way quicker for sure!
Build no two the same continues. Panels lap on one side but on another. Different lengths cut angles notches.
Crude awesome!
The driver side needed a little hammer action. This seemed to be the carry all side of the junkyard runner hammering the aluminum flat deck with the parts bounty it hauled in life.
Truss-head stainless #10 flathead machine screws will be used on the aluminum body panels that thu bolt without steel frame.
Stainless closed rivets will be used on aluminum to steel OE frame for better structural integrity. Lower new frame and coffin supports could use screws but i’m not.
Galvanic corrosion was most likely not a design factor back in the day and if it was machines were not designed to last long enough to care.
Stainless is the best choice and as much as I want to put screw back l, rivets are more secure due to the load bearing nature of Tucker Tolerance!
Panel mock up coming along nicely.
Passenger side floor was another carry all took some serious hits in addition to
the rear.
Rear panel took some abuse from the sawzall on the OE body cut and junkyard wars. Straightened out but it will need a cut and blend for the donor body has the rest of that upper panel missing.
Cleaned up and straighten out more OE body.
2/3 of the bench seat trim is missing. Marty has a bunch of OE body that the donor replaced we can repurpose.
The Trim below the gas tank flange is mostly gone. Marty OE body will solve this issue as well.
Impressive how much of this aluminum survived junkyard dog life!
Marty’s rehab journey back to the sno already producing smiles per milestone!
Stainless flathead screws, hardware, and rivets will maintain Tucker Tolerance and load bearing specs at various connection points.
Moving onto the front bench trim. The driver side panel is all that remains. Pretty sure Marty OE was one piece cut and bent for the three sides surround.
My replacement is going to be OE Marty Body but a few pieces due to material size limitations.
Should fit the story nicely when complete.
Replicated the passenger side bench seat trim off the driver side OE factory survivor panel.
Added a backer to where the donor body font bench trim butts for rigidity and blending.
Marty’s rear door replacement is based on legendary OG input that sheds more light on acceptable Tucker Tolerance!
Mock up take 1 revealed I needed to cut and reweld the door hinges after some expert guidance.
Take 2 is going to offer great views as a result!
Welded the coffin box supports to the frame checking that box.
The OE transfer case access panel had no fastening. This was a rattle point that can easily be addressed by utilizing the existing hardware the panel sits on.
The need to remove this panel would be rare and well worth the additional hole modification
and hardware hassle. Helps tie everything together maintaining Tucker spec and load bearing aluminum!
This completes the body portion of the project :)
Removed the headlight brackets with ease after 73 years of bonding.
Started taking the body apart to final prep the frame for glass bead and then paint. They don’t stack up to much.
Confirmed that I can get all the lower body panels attached to this point before installing the engine and drive. This allows me to install the sides, back, and roof before mechanicals which will be a great phase for the winter.
SNO is coming and we must be respectful to the other Tuckers grazing at the East Coast Preserve!
Tucker as some point in history started using trunk paint on the interior. Marty’s 53 vintage had none but the 58 donor did.
I removed the material from the frame ahead of glass bead blasting. Wire wheel, respirator, and glasses here. Who knows what’s in the dust 💨☢️
