Long shot, but my Ford 254 flathead was acting somewhat similar, turned out to be the fuel pump, ran fine at low RPM but once it sped up the pump was not pumping enough fuel.  My pump was still pumping, but not enough.  Cleaned carb, made sure all lines were clear, installed new fuel pump, problem solved.  Something to consider or look into anyway.  Good luck!
