Mary Ann a real piece of Antarctic history
3512b
Junior Member
Us old ice hands have a soft spot in out hearts for these old beasts
54 inch track pads direct drive transition and a D 342 or the high power ones had a D 353 engine
I will look I had some picture of the 50 th birthday party they threw for em the last time I was down
hope She goes to a good home not for scrap! tuckerville?:clap:
http://antarcticauction.com/section/construction-heavy-equipment/
loggah
Steve, It definitely would be a shame to scrap them !! you ought to own one to go with your snow trac!!!!:biggrin: funny its named the same as the first steam lombard !!!!
I had to look that one up I had never seen a wide pad 8 I know a guy who operated a 9 on a daisy chain in Thompson pass during the construction of the Alaska pipeline
3512b
Junior Member
Case we want to set up a joint venture on saving the old girl, some pic
from the B day and around the town, Pulling the balloon building after the D8 couldn't
3512b
Junior Member
some more pic
loggah
Steve, That last picture machine must have had a d353 engine in it.Nice conversion of the Balderson chip blades. Don
Pontoon Princess
Cattitute
scott scott scott, do we have room in the back 40? tuckerville minion
3512b
Junior Member
with that beast you can make all the room you need!
I know those are d-8's what is with the space between the cab and engine I knew something looked off with the cab now I see it are the frames stretched also
3512b
Junior Member
they stretched the frame for more track to lower the grown pressure and more pulling power. Gerald Christ and Russ did a lot of mods to the frames as they did crack. there was a belly tank there too so I was told
Gerald is on the slope now and Russ should be coming off the ice now.
that's cool there is a lot of extra space in the bellies for fuel and those things can drink it down. when you say direct drive transmissions do you mean they don't have a power shift trans?
3512b
Junior Member
nope direct drive....... no top rollers either, I am trying to get a couple of ice friends to join the forum and to come to Mt hood, They ran them so have more first hand knowledge of them the traverse and the tuckers. Dave worked with Tucker on the tucker they flew to waist divide. I hoping he come to Mt hood in Apr.
Me I was stuck in the power plant keeping my D399s going drinking coffee and getting fat on doughnut's
Very interesting - are those wooden timbers to support the upper track sections instead of rollers?
300 H and H
I noticed those as well. I wonder if they help to keep ice from building up in the rails and pins. When operaing they would fill the gap and let nothing in the rails. Rollers may build up with ice and snow and pack this between the rails. It would also affect track tension. JMHO. Hope some one here knows the answer..
I've been told the D343 engines (DOHC 4 valve motors in 1962!!) were not easy to start in cold weather. Obviously these guys had a way figured out!
loggah
Replacing top rolls with hardwood "sliders" is an old trick from the logging industry.you didn't have to worry about top rolls freezing up.Heres a picture of my old 1952 oliver cletrac ,used in Maine to haul Lombard sleds. I have since put new hardwood sliders on her. As far as the chains packing with snow most for use in winter had cutouts. Don
3512b
Junior Member
I just flew up to Prudhoe today, on the flight was a crane operator headed to Pt Thompson. He just came from McMurdo and I asked him about Mary Ann. He said he walked her down to the ice pier under her own power to load on the ship this years ship. So She was running then.
He said there no more stretch 8 in McMurdo now. course there a few down in crevasse and at little America and sunk in the bay.
Scott would look good with your tuckers!
mog5858
you will be happy to know that Mary Ann now has a nice new home and is beaning well taken care of. a friend in California owns her and makes sure she get out and walks around a little.
3512b
Junior Member
Good news! If he needs some info help let me know. Old RUss is in Calif he's got more experience than anyone
Pictures?
sno-drifter
This old girl has never been to the ice but is building the new Sno-Cat house. Cable blade and diesel fluid torque converter.
JimVT
scott, it looks like you need some rocks.
is this at your home?
jim
there are a few cable cats still working for a living around here. funny how much terex stuff is also still being used
loggah
Scott,I miss running the old 19A D-9 i had, she was a fast stepper until you got half a blade full of material. :biggrin:Those look like Fleco sweeps on that machine, nice !!!!!:clap::clap:
I still remember the day I sunk a 9g in the tundra I had to step up when stepping off the top of the tracks a 320 excavator some timbers and 4 hours later it was freed from it's hole.
mog5858
she was out at Sand margarita show. i bet she will be out there again.
the nose art was re-dune but better job is yet to come. she got a little paint on her fuel tank but i don't have of pic of it.
mla2ofus
The stretched cats must have been built off a 36A. I spent many, many days pushing rock to a crusher w/ one. Bit of trivia: Does anyone know where the "johnson bar" got it's name from?
Mike
sno-drifter
You IDed it Don, a 19A last year 1957, hyd tilt on blade and ripper. Here is a 2U which I rigged up a hyd tilt too. Makes it a real worker.
3512b
Junior Member
Here's some pic of one of the 24 fresh on the factory floor
One of the guys in the photo was still alive when I was on the ice in 2002 and living in Florida.
I use to have a parts book for them and don't know what happen to it
Olds himers setting in I guess.
1/2 of the production went to the ice the other 1/2 went to the arctic to build /support the dew line
some had D353s and a 500 gal fuel tank on the ft and were traverse Cats.
Mary Ann and the others went to Christ Church got frame ups with the ropps cab and the better blades and reinforced the frames
Scott
thought your were just throwing up a shack to hide a few tuckers in
If you putting up a "CAT" house I will be down! can I be the bouncer?
:clap:
