1968 Tucker 442 New to Me
Transfer painting in progress. Seals here this week. Hopefully pop transfer back in. New ignition runs sweet. Shifting is great. All is well moving forward!!
New u joints for input shaft. Seals in tomorrow for xfer case
Hit up the topsfield fair antique tractor pull. 41 jd h came in 8 out
Of 10. They still look and sound the best. Friend dropped off my seals there for home with e time for install. Case in frame tomorrow then steering time!
Looks like you may win the race with old man winter. Great looking project and should be reliable to run after all the work you have done. :clap:
I changed my username to Track Addict something more fitting. First step in recovery is to admit you have a problem.
Seeing as I no longer have a Blackfin and there are no more Bluefin tuna in the ocean here it is time!
Steering back. Hydraulics check. Transfer magnetic plugs and front diff. Front tires and rear driveshaft tomorrow ! Driving by this weekend.
Do you have any problems running an open sided air filter? The engine compartment seems fairly open to snow thrown up and around by the tracks.
Cletis
Never had an issue with the open filter. Snow doesn't seem to get anywhere in there. The under hood temp is pretty warm and generally just the sides of the motor down low might have some water from snow dust.
Little electrical work. Set some wires on Fire with plasma cutter. Little char on the cat paint but will live. Put the powder maker together.
Making cover for top orange out of brushed stainless. Two 4 1/2 riound speed hut gauges tach/Gps speed the other volt/oil/water/ fuel. Snow cat sticker centered maybe. Black grab bars on top of stainless left and right
Choke key placards
Wired up cleaned up. Positioned for pontoon and track install.
Letting the tucker funds build for s bit. Wife is getting pissed seeing as we still have some unfinished house 5 years later!
Two great things in Massachusetts this November. I already saw snow at the house and we have balance back with the new Governor!
