Rear hitch needed to be reworked. Welded in a bushing to return it to 3/4” pin.
I giggled at this comment. Not sure *tucker-tolerance* should be your goal. Great alignment
Marty’s wheels headed down to Shrewsbury,MA to spend some time at the axle/diff spa for some rejuvenation.
Burnt Meadow Sno Club Thiokol housings on the relay for life med flight for outpatient surgery shrinking our 2100 down to 8’wide.
Rainy hot humid says Sno Cat to me.
Started cutting out cancer and patching the other side of the frame bottom.
Also added the missing hand crank support bracket that was torn off when I got it. The bottom takes all the abuse.
Using pictures and a caliper to figure out the size in relation to the 1 3/4” tube I think I got it with in OE Tucker Tolerance spec and a close enough repop for the storyline!
Shop got the donor rear ends apart and unfortunately they spent a good amount of time under water:(
Going bring down Marty’s OE rear ends see how those look and hopefully cobble together the best parts for service life.
TBD
Got all but two of the exhaust manifold bolts off the 69 442A. The 25” blocks between the 251 and 265 should interchange the exhaust manifolds.
Little more fines needed on the two remaining bolts.
Averaging about 12” per hour from OE tube to finished patch with generous beverage breaks and the occasional safety meeting.
40-50 hour job in an ergonomic setup with half decent tools and experience.
Such a small part of a Tucker project to give perspective on the work involved.
My new set of Hudson Bearing Turbo Socket difficult fastener removal tools showed up today. Great design for rounded rotted fasteners and a must have for the shop!
Was impressive on the first of the bolts. The other one going to need a little more access and finesse but this manifold is in great shape from what I can see. Side engine panel needs to come off and battery tray need to go for better access.
Sourced a nice one for plan b but this 265 was a late enough model they eliminated the exhaust damper which are problematic for this use case. 251 and 265 industrials seem to be same 4 bolt exhaust manifolds so far…..
Another shout out to Turbo Socket! Wouldn’t have got these bolts out otherwise.
My theory has proved correct. 251 and 265 Industrial use the same intake and exhaust manifold but the later 265 eliminated the heat damper.
Intakes are the same as well. 1953 251ci has a 1121704 then a 2. 69 265ci has a 1121704 then a 12. Both look identical.
Exhaust manifold same as well but 1953 251ci 1116679-1 has heat damper. 1969 265ci 1116679-2 does not have a damper.
In conclusion, if you have to source an exhaust manifold for 251/265 25” block, 1116679-2 is the better choice.
Now to separate them…
Very precarious work in this precious exhaust manifold.
The pipe flange was tough. No way the long bolts connecting the intake to exhaust are coming out without breaking the flange.
Consensus is to drill the bolts out of the exhaust manifold. Odd how the 1953 OE came apart but the 1969 is frozen in time.
Mouse was not happy being deported:(
Strong morning with some assistance for change. Marty’s OE manifold ready. Calyx manifold dressing is the finish of choice to preserve and protect. Exhaust will get the same treatment.
Got the donor exhaust manifold separated in the mill drilling out the frozen shanks. Quality bits with lots of steps and slow is pro.
Lots of work but happy with the result. The intake to exhaust manifold gasket became petrified steel like a dinosaur bond. That was the most work cleaning it off.
New intake to exhaust hardware on the way then installation.
The 53 manifolds were less stuck than the 69. Thinking the altitude helps these old cats maybe.
Flathead exhaust manifolds are prone to breaking by design from the heat cool cycle and different expansion rates.
This is the best practice solution from my research that eliminates the two bolts for long studs plus brass nuts everywhere while maintaining the conical washer nut combo on the outermost exhaust flanges.
Brass washers would be a better solution but the strength required to hold the dual flanges up top requires steel.
Intake and exhaust manifolds installed.
Procedure for installation is to gently snug the Intake to exhaust manifold bolts after applying antisieze to the shanks and threads. This allows the flanges on the block to align first.
Install the manifolds on the block then slowly tighten the nuts from center out slowly in many steps to 20 ft/lbs.
Then tighten the intake to exhaust manifolds slowly in many steps to 25 ft/lbs.
You can certainly see how much these manifolds suck in and conform under load.
Cast is a blast!
Almost had the bottom frame repair complete but Mig switch decided to be auto on. Hope to have buttoned up am as well as the final welding before frame goes back upright.
Getting the coffin box frame supports and lower side panels mounted up is next task.
Once I figured out the tetris pieces just the donor frame support needs a trim so far.
Frame repair complete!
Big thanks to Matt the Welder for coming by and cleaning up some of my hobby welds.
Frame is in position for winter work fitting all the lower body panels, coffin frame supports, floor panels, wood panels etc.
Transfer case reseal, transmission refresh, clutch, throw out bearing, and other work will continue as well. Goal is a spring frame paint and runner on rubber tires!
