Dealer just hauled away the Bobcat ct235 after my demo.
First off I am impressed with the value of this machine. Great price for a very capable machine. There were lots of easy to reach dipsticks and filler ports that did not require a contortionist to find or access. The loader control was in exactly the right spot, most of the controls were in good locations, the steering tilted and adjusted within a wide range, the suspension seat was a WONDERFUL feature... just like Charmin, it was soft but got the job done
Probably best tractor seat I've ever had the pleasure of sitting in, it was apparently adapted to this tractor from some of the commercial Bobcat equipment. Levers for PTO, 3pt, etc were in good, but perhaps not perfect locations. I'd have preferred them moved forward a few inches but that could be just nitpicking. The loader is not the same loader as the Kioti loader, not sure who makes it, but apparently its being redesigned. Perhaps waiting until the next generation would probably eliminate the current loader incentive. I gathered that the supplier was having trouble getting them loaders and that is the reason they are changing, so a change is not performance based.
Secondly I am critical of several points, and some of them may be deal breakers. There is a hydraulic filter that sticks down under the tractor that is exposed and vulnerable to be knocked off. Is it likely it would be knocked off? Probably not on my property, but if I was a commercial buyer I would seriously consider that as a problem. The hydraulic quick connectors are under the right side of the loader arm, parallel to the ground, at the bottom of the framework and MIGHT be vulnerable to being knocked apart, hit, etc by branches, debris, etc. I think working in the woods could be an issue with this tractor if it was used for clearing scrub, etc.
One thing that I really did not like, seriously think is a design flaw, is the lever to engage the 4wd. It is 1" above the floor in front of the left foot. You have to take your eyes off your forward travel and reach WAY DOWN to engage the 4wd. That is a problem. I found it very very awkward. Another problem with this location is the proximity to the differential lock. Its located right next to the differential lock at essentially the same elevation. I honestly think that it would be pretty easy, when trying to engage the differential lock, to accidently put your foot on the 4wd lever and disengage the 4wd when you actually needed the added traction afforded by the differential lock.
Now those bad things aside, this was a comfortable tractor to run. Even if the ergonomics are "last generation" compared to the New Holland 2030/2035, the tractor was still powerful, capable, comfortable and clearly will do what I want done. The engine ran as smooth as the engine on the New Hollands and was actually quieter than the engine on my TC24d.
Overall I'm favorably impressed. I'd say the odds of buying this tractor are 60% in favor, 40% opposed.
