The cabin remodel
After the big clean up, this is most of the drop, minus the boards I brought home to make the base for the cooking/ eating area. Not too many 14’ left, mostly 4’-7’. Cabin neighbor wants it so it will go to a good home.
Looking good. I would like to add that it is not code to put anything in front of an electrical panel like you have pictured. Just saying, not trying to be a pain in the ass. :) That is going to be a helluva cabin. It already is actually.
I’ll have to check that out, always been instructed in the industrial setting that nothing can be directly in front of the panel door closer than 36”, maybe different for homes, but I’m off grid and nothing gets inspected out here, the zoning allows the building of structures but not subject to any code or inspections.
For years it was always standard procedure to put the 45KVA transformer directly under the 480/277 panel that feeds the 120/208 panel. Suddenly, one day the new NEC came out and it was a no no. :ROFLMAO:
Is that the same NEC that cannot determine whether to put the ground plug on a duplex up or down? :whistling: :whistling:
The intent is in an emergency somthing on the floor could make it difficult reaching the panel, I can easily reach the panel over the hw tank and when the floor is done it will set on the floor, I granted myself a variance.
Well there is that and also working on a live panel there is that big hunk of grounded metal that can ruin your day if one is dumb enough to get hung up. Please, don't ask me how I know. :ROFLMAO:
You do realize that I’m off grid on solar with an inverter that can be turned off in one second, I don’t work in hot panels, even at home I turn the power off at the main breaker. Zero chance of getting zapped that way and up here I’m just with the dog and pretty sure his first aid card is expired.
Safety is no accident!
Even though in my younger days I did drill 3 live 480vac buss bars for an extra 200 amp panel. But they were real big so no chance of hitting the others.......
That’s correct, I don’t take chances with electricity ( I don’t work on hot wires) or take chances with fire ( never burn outside unless it’s raining or a lot of snow on the ground) those two things I never chance. If flipping a breaker don’t fix it, the main power turns off and verified off, before I go into a panel. Up here on the mountain emergency help is a long way away and the gps will not get them here.
Many years ago, my dad was wiring my basement bedroom. I had built it with my own money and did a pretty goo job but he insisted on "teaching" me how to wire a wall plug and a light fixture. He was doing the light fixture, standing on a short, wooden stepladder, and working with the power "ON." At 13 years old I knew that was dangerous, so I asked him why?
He explained that so long as he only touched one wire at a time, it was safe. To prove it he touched one black wire, and nothing happened.
Then he convinced me to touch the same wire. Nervously I slowly let my hand creep up to that ominous, exposed copper extending beyond the black plastic sheathing,,,, and got ,,,knocked on my ass.
Apparently, using the adjacent drainpipe for balance was not recommended in the instructions.
I have never worked on live circuits since.
Not sure I ever trusted my dad again either.
Dads, my dad shot a hole through the kitchen stove showing me how the safety worked on a 22 single shot rolling block rifle, when I was about 12. Getting shocked or burned sucks.
First photo bare wood, second is with one coat of spar urethane varnish oil base, the oil base darkens the wood some and gives it the golden tone, while bringing out the grain and knots. The look I want will require 4-6 coats, one coat took 40 man hours to complete, next spring I will sand with 220 and do another then repeat the process. Spar urethane is a marine product and will last more than 30 years and will be easy to keep clean and maintain.
Finall got some varnish on my bathroom door that’s been hung since 2020, I had to sand it because it oxidized from being in protected for so long.
My cabin neighbor got extremely lucky I made that trip , he bought a 40’ container and had it delivered. The plan was to come down my driveway from the forest road down to Dave’s place the continue down golden lane and out. They passed my place around 2pm, a half hour later I got asked for help. What happened was that on the last 300’ there was a tight corner where the trailer slid off the road and the hillside is a 40 degree slope and when the truck tried to advance it just slid further, then the truck got stuck.
Dave made a video and put it on YouTube “ shipping container rescue” by David Howard. Had to first drag it off the trailer uphill, pull the truck out then drag the container down the driveway, the next day we placed it in the spot he wanted, but not without him getting attacked by hornets. In all it was a couple hours and some diesel, but if I had not been there it would have been thousands for a service to do it, or it would have still been there in the spring.
I now have to do my last field job then I’m retired, it will be done at the end of October, then I’ll make one more trip and shut the spring down, but leave some water in the tank for a couple winter trips.
Headed back to the work cabin on Saturday to winterize the place, disconnect the spring, run the d7 and loader then pull the batteries from the loader, cut and pile a few more dead trees and do some shooting. Also try out my new diesel heater, 8 kw and suppose to run 30 hours on a gallon. I hope it works well so I can get away from the Mr buddy propane heater, it is expencive to operate and although it’s safe for indoor use, there is some discomfort over a long period. Next year when the wood stove is back in it will work for keeping warm at night when the fire goes out. Pictures upon my return.
You can see on the first picture the temperature in the mountains here, it was on a pass a couple thousand feet higher than the cabin.
Can’t say enough good things about the cheap diesel heater, after installing it and turning it on, the transformer is only using 23 watts, that about the same as a cell phone charger, you can’t hold your hand at the discharge nozzle thru the window more than a few seconds before it’s too much, similar to a heat gun. It was 48 in the cabin when I turned it on, ran on high for a few hours to get to 65 then re filled the tank right before dark and turned down to medium, kept it 70 in the cabin with low 30’s outside, in the morning it used a half gallon over night. In the middle of winter it would have to be run on high, a better plan is to get another one and install it in an opposite window and run both on medium. After the cook stove goes back in next season I would only need them at night. Diesel heater is a winner.
