Since it's there, are you going to have it clear the whole trail?
Can the how reach out to your dock and push it back down?
hay!! with that view....Squerly would have just built a house where the rock was!!!!!! nice solid foundation
Looking good Doc!!!
And I would have built there also but the roads to get there are not vehicle friendly. I'd have to hibernate in the winter. If I didn't have to work maybe that would be a good thing.So I have questions
1. Was that a 50/60 series Deere?
2. Did it have a hydraulic quik tach for attachments? If not, how much hassle with wedge pins & bolt to changeover?
3. How handy was the grapple?
Machine looks to have tail weight which busts 14K gross so how did you haul it?
I've been looking at the 35/50/60 for awhile to replace my old TLB. Dealer keeps getting in low houred 60's with long arm & weight which push past my self imposed 26K GCVW.
The narrower 35 is easy to transport & fit down woods trails but the larger units have more weight & reach for bank mowing & help pull eq. out of the mud..
I had a big dozer fix the same spot last year. The rock was to much for the dozer. It was way to big and so far back into the hill. At that point he operator suggested a hoe with a hammer but I could not swing it then. After the land slip we could no longer use the road so I had to go with the hoe and hammer to get er done. The hoe was the right tool for this job for sure.Would a dozer with a 6 way blade have worked? I think it would have been much faster... Or not?
That was a series 60.
Rented it and had it delivered. It came on an 18 wheeler flat bed. Over kill but they haul a lot of different setups.
No quick attachments. Manually changing over was not to bad. the bolt and pins were easy peezy. Snapping in the hydraulic lines was the toughest.
The grapple / thumb was used primarily to carry the jack hammer attachment to and from the work site. Was able to lay it down and do a little work on the way then pick it back up all from the seat. Handy but not necessary for the majority of yesterdays work.
If you would not be hauling it much you could hire the hauler when needed. I would love to have a unit like this on my property for general maintenance and taming the terrain but I sure cannot afford one, darn it.
