Snowtrack restauration project
I am changeing the front gear drive from a Master to the smaller SnowTrac style. I'll check the x-member to see if there might be a clearance issue with a 17 tooth "small" gear. Thank's for the tip though.
Here is a photo of the Master before any work started..
I am building new tracks with the standard SnowTrac grousers. Have a full hi-cab instead of the pick-up version.
that sucks to see a master all butchered up like that I think they look cool with tall groomer cabs lots of room for cowboy hats. do you still have the hydraulic package lookslike some of it is still on they fender
Niels Excellent idea replacing the front gear drive from the Snow Master to the smaller SnowTrac style !!!!
For the electronic throttle pedal i used a GM #258 30024
MONTE CARLO 2006 /2007 GRAND PRIX 2004 / 2008
On my installation i shorten the levers 2" ( see the picture )
For the custom sprockets i can give you the complete procedure if you want ??
LOUIS
That is not butchered Don, that is a factory cab- like the ones used in the Sapporo winter Olympics. I also think those tall cabs are great! looking forward to following this build:smile:
Nwering, if you have a chance could you post some pictures of the back of the cab and how it joins on to the machine? I have always wondered how hard it would be to remove the "top" on one of these half cabs, I assume the back wall is one piece all the way to the floor on each side of the door?
That's correct. This was a factory option, actually also for the standard SnowTrac. Both high and low roof versions, and sometimes with a triangular toolbox on each rear bench. One thing that make them not so smart.. is that there is a tendency for the tracks to throw up snow that settles behind the entrance door. This makes the door allmost impossible to open from the innside ? Looks darn silly when you are trapped innside.
All the panels are bolt on. Many small panels.. I'll post photos later.
One other thing. I dont want to hijack Louis' restoration thred, even though it will also cover the Ecotec upgrade. Should I make a new seperate thred?
I wasn't referring to the cab I was talking about the cut down tracks. I never thought about the cab door getting stuck with snow, there is one here I tried to acquire some time back my plans were to add a roof hatch so I could load the bed to the and still get in and out
Niels
For the benefit of the Snow Track community, it would be highly useful to have all the Ecotec posts at the same place !!!! What do you think ???
I will post in more details the ECOTEC conversion program
A - Engine / B- Transmission / C - Fuel system / D - Exhaust system
E - Cooling system / F - Computer system
A - ENGINE " GM ECOTEC 2.4 LE 5 "
First picture:
You see the intake and exhaust cam position transmeter (with the green tape)
With the electrical connector in place, the clearance with the strap was not perfect
Second picture:
Red brackets i have made to hold the cam position transmeter in new 180 degrees position
Third picture:
You see the new position of the cam transmeter with the custom brackets
Fourth picture:
View of the clearance between the connector and the strap (intake side); you can also see the thermostat housing (the overflow port has been welded closed) NOTE: you must install a new ground wire ( braided ) in the original mounting bolt hole
Fifth picture:
View of the clearance between the connector and the strap (exhaust side)
Sixth picture:
Custom adaptor for oil information: oil temperature (gage), mechanical oil pressure ( gauge ) , low oil pressure light ( VW type ) and computer oil temperature
Seventh picture:
Opening in bottom pan for engine oil drain plug
NOTE: the Ecotec engine in the Snowtrack is not in the same position as of the GM front wheel drive car; it is almost vertical now ; you must re-mark the deep stick to make sure you have the right quantity of oil in the engine
to be continued ..............
Louis
A- Water temp sender ( gauge )
B- Thermostat housing overflow port has been welded closed
C- New ground wire ( braided )
D- New position of the cam position transmeter
E- Cam position transmeter custom brackets
F - Custom adaptor for oil information
ENGINE READY TO INSTALL
Louis
Great photos and descriptions Louis! They will make my work so much easier.
I will continue to post my conversion work on your thread, to keep the Ecotec info together.
In the picture of my last post, #190, i forgot to specify there is a clearance issue with the two bottom bolts fixing the adaptor plate to the Ecotec engine; i replaced the two sockets head cap screws by two 90* countersunk flat head screws!
In this picture, ECOTEC engine intake side
A- Vacuum port for brake booster : permanently shut off
B- Vacuum port : permanently shut off
C- Cooling system port : i have installed a valve to remove air bubble from . . the cooling system
D- Crank case vent port : must be open all the time
Louis
B - Transmission
The transmission must be in fresh rebuilt condition (to cope with 185 HP)
I've installed all new german quality rubber transmission mounts
I've grinded the bell housing for the bigger 1600 CC 130 teeth 12 volts flywheel (like the ECOTEC engine flywheel)
I've installed a new high torque starter IMI-101 # ACC-C10-5767; " the BOSH starter can not crank the ECOTEC engine
The clutch release mechanism and the clutch cross shaft must be in excellent condition because it has to handle the heavy duty clutch pressure plate!!!
I've also installed a new clutch release bearing
Note: You must install a heavy duty 2100 lb KENNEDY STAGE II clutch pressure plate to handle the torque of the ECOTEC engine
Louis
C - Fuel system
Many ECOTEC dune buggy on different forums use this fuel system and it works fine in my ECOTEC snowtrac
A- Fuel filter "to protect the fuel pump"
B- High pressure in line fuel pump ( WALBRO GSL-392 )
C- Fuel connectors ( DORMAN # 800-120 , # 800-121 )
D- Fuel filter regulator ( WIX #33737 ) used Chevolet Corvet from 1999-2004
E- Fuel connector ( DORMAN # 800-155 )
F- Fuel gauge : EFI fuel pressure gauge ( FUELAB #71501)
Fuel gauge adapter (MR.GASKET # 2975)
Note (1): Use only high pressure fuel rubber hose
Note (2): Return line must be at the bottom of the fuel tank
Louis
My Ecotec engine arrived by ship from the US today:biggrin:
Hopefully I can get it ready by next winter...
NICE ENGINE !!!
Alternator missing ;
Used AC DELCO Part # 13944
Shorter strap for alternator ; GATES # K050345 5PK880
QUESTION ;
A - Are you full time on the ECOTEC projet !!!
b - Tell me something about your experiences ( mechanical / technical ) in custom project ????
LOUIS
[ame="http://www.youtube.com/watch?v=XrJVDoAW4og"]http://www.youtube.com/watch?v=XrJVDoAW4og[/ame]NOT A SNOWTRAC (WINTER TOY ) A SUMMER TOY !!!!!!!!!!!!!!!
1953 NASH HEALEY PININ FARINA ROADSTER " 1 OF 150 "
SOME TOOLS I USED TO KEEP MY TOYS IN TOP CONDITION !!!!!!
[ame="www.youtube.com/watch?v=cc4dx9T3viQ"]www.youtube.com/watch?v=cc4dx9T3viQ[/ame]
Now, winter is coming; sorry for the delay
Let's get back to the Ecotec conversion program description
A - Engine, B - transmission and C - fuel system have been described
See page 10 , post 194 for the last one ( fuel system )
D - Exhaust system
For the Ecotec exhaust, I've connected in the bigger exhaust (1 3/4 in. tube) that i previously made for the high power VW engine and i used a straight flow muffler (see picture)
NOTE: For the exhaust, 1 3/4 in. is OK but 2 in. is even better
E - Cooling system
The cooling system is the most IMPORTANT in the ECOTEC conversion; the three parameters that impact the cooling are:
Air Flow -- Thermodynamic -- Weight and balance
Air flow:
In a vehicle running at 55 M.P.H. , the radiator must be in front to get the benefits of the air flow; in the SNOWTRAC , the travel speed is generally very slow; there is no air flow to impact the cooling system. So the radiator position can be in the back of the vehicle
Thermodynamic:
The thermodynamic is directly impacted by the air flow; a bigger radiator must be used with a slow vehicle like a SNOWTRAC that do not have the benefit of free air flow
Weight and balance:
The weight and balance in an oversnow vehicle is very important; too much weight in the front (nose heavy) will limit the performance in deep powder snow. The weight of the radiator , electric fan and the PRESTONE weigh around forty pound; forty pound upfront of the Snowtrac will directly impact the critical balance (performance) of the SNOWTRAC
In the SNOWTRAC ECOTEC Conversion there is no adequate place in the engine compartment with the front engine mount to install the radiator , so a rear position was selected
The use of heat exchanger ; the black tubings that carry the “ Prestone “ from the engine to the radiator and diffuse by the splash of the snow at least 35% of the heat are an important part in the complex cooling system ( see VIDEO page 5 post 81 )
To install and protect the radiator and electric fans I have made an aluminium capsule
NOTE
The capacity for the ECM ( engine computer ) to monitor the temp in the radiator and control the fans are not good with a radiator installation at great distance from the engine ; so I installed a HAYDEN 3654 “ in radiator electronic thermostat “ to control the electric fans at the selected temperature
You can see all the picture at page 5
HEAT EXCHANGER TUBE PICTURE ; PAGE 5 POST # 82
RADIATOR CAPSULE PICTURE ; " POST # 84
FRONT ENGINE MOUNT PICTURE ; " POST # 86
You can see a video during the fabrication of a radiator capsule for an other snowmobile project ( the process is the same for the SNOWTRAC application):whistling:
[ame="http://www.youtube.com/watch?v=3K72C_NJw_o"]http://www.youtube.com/watch?v=3K72C_NJw_o[/ame]
Hi Louis, The more I see of your project, the more impressed I get. My own Ecotec conversion is coming along slowly. Before starting the conversion though, I want the rest of the Snow Trac to be 100% ok. I´m in the process of changing all the bushings, bearings, tires, renovating transmission etc etc. Hopefully I´ll get there in the end :-)
What tyres are you using for the big wheels? I have some Alpine-Guide tires, but they look a little to wide... I also have some Bombardier (?) slick tires. they look very good, but I would like to try the Alpine-Guide tires if they fit inside the track guides..
Alpine-Guide on the right in the photo..
Hi nwerring ,
I will use this occasion to give you and all members of Forums Forums, my best wishes for 2017
You will see on the picture I've used four Alpine guide tires for my big wheels.
In my opinion, they do the job very well !!
Here are some comments for the installation of the Alpine guide:
1) If you are planing to do business with a tire company and they say they have a $ 10 000 computer assist machine , please do yourself a favor and run away as fast as you can ! A new technology tire machine will surely damage the tire, the tube or the rim and they will say the $ 10 000 machine is OK and your tire and rim set up are wrong.
2) The only way to have a successful installation is to use a vintage manual machine
3) During the installation, you should use powder between the tube and the tire. Between the tire and the rim, you should use soap.
4) The temperature in the shop must be at least 25 degrees Celcius and your assistant must apply heat with a heat gun on the tire
The three most important things are: HEAT, HEAT, HEAT
If the tire reaches the right temperature it will go easily!
Hope you will have a success with the installation !!!!!!!!!!!!!!!
LOUIS
Hi nwerring ,
4) The temperature in the shop must be at least 25 degrees Celcius ...
LOUIS
When I went to mount the big tires I bought from MNOutdoors, I was having a heck of a time. I called the Harley shop where I bought the tubes for advice. The tire guy asked: Do you have a coat on? When I replied "yes", he told me my shop was too cold to mount those tires. After getting the shop to temperature they went on easily using the cheap manual tire changer I bought.
I too, would like to find a 6 lug big wheel. I need a spare.
LOUIS
Just like mounting dirt bike ice tires or Trelliborgs. A wasted effort unless you let them heat by the woodstove for the night then immediately shoe them onto the rim!
