SnowChicken Bombi Build
I had an issue with the coolant temp after the install and Norm was very helpful over the phone. Easy fix. Mine was installed in the summer of 2019 and has been flawless.
I used a Lokar Throttle Cable
The AFI kit came with it, just use a pump that puts out at least 50psi, return line is T and controlled by Vaccum pressure
AFI Kit came with it
Brass T: 1/2” MPT x 1/2” FPT x 1/2” FPT
Picked it up at Auto Value
AFI Kit comes with great manual and great Tech Support from Norm at AFI!
Thx for all the inputs! EFI installed and running - a little more work to do on the throttle linkage… PITA!!
I need a set of Snow Tracks (prefab or parts to build DIY) for BR100 - have summer set on which requires a groomed trail if hilly snow and flat if powder - does me no good here in Colorado... I need to do what HillBilt's doing a few posts back - lots of powder on many feet of sun/wind blown snow pack! Let me know... In Colorado - have Jeep, will travel!
@Caribou, you should post this in the classifieds/Wanted section.
Hi Everyone,
I just read this whole thread - obviously, without the Bombi in front of me some things were hard to picture.
I have two Bombis (yes, I'm sick and not yet cured) and am going to do an EFI on each this summer (pretty certain anyways!). I have that and a little bit of track work to do on one.
Question -
After all your experiences (I see two of you, at least, have done EFI), which EFI kit do you recommend?
Thanks!
Hi Everyone,
Question -
Thanks!
The Holley Sniper Autolite 1100 is going to be your best bet I feel and is the one I did. It has the same bolt patter for the stock 1.6 intake and same throttle action so minimal modifications are required to make it work and is pretty much a Direct bolt on as far as the throttle body goes.
Netflix and chill….no thanks! I want a ride on that bumper couch!
I wanna race... :) Looking good Hillbilt. Hopefully,I'll be able to get back on this project this winter. Torn my ACL last season snowboardin. Seems like I'll have this winter off and it's bomb time.
