my steel ones cracked that is why I'm back to composites.steel 5 lug is what I need my cast one cracked.
The factory tires weren't much more than a bald motor cycle tire alpine guide makes a 4.50x 16 tire that will work. and is pretty much bullet proof there is no weight on the rear tire it just floats and tensions the track. I see no need to add weight just so I don't have to check air pressure.Any thoughts on foam filling? I know the pros and cons, but in light recreational use, is it really very important?
The ST came with new 3.50-16 motorcycle tires to replace the 3.50-16 Cheng-Shin MC tires that are currently on it. I imagine they are lighter ply rating than the OE units. In this case, I can see foam filling as another big advantage.
Any thoughts??
Pretty much what I had thought. I think I will just go with air to begin with and see how it goes. The added weight seemed like a waste since the ST is so comparatively light to begin with.The factory tires weren't much more than a bald motor cycle tire....
Got her home and off the trailer. Seems to run and move well, no brakes...
If anyone recognizes this rig, let me know. I'm interested in some of the history.
and a few more pics...
http://ImageEvent.com/reddog/1967snowtrac940
that's a narrowed down snow master I have seen the pics before can't remember where it does have the rare brass boggie also the tracks look a little loose the front wheel should be off the ground. the reason the rear tire looks small is be cause it extends out past the rear by about 12 inches. other wise looks well cared for.
Yes, you should install the middle bogie.Looks like the rear rocker has a place for a middle bogie. . .
Think I should install a middle bogie on the rear?
Just a thought:
My recollection is the Snow Tracs are geared higher than Snow Masters or Track Masters making the Snow Tracs faster. When this machine's tracks were narrowed was the gearing changed?
Just counted, looks like 30 teeth on the front sprocket.
So much for my plans to set the world land speed record for a snow trac....
