Rattlesnake radio site
PJL
Today I ran a radio tech up to one of our repeater sites near North Bend to make a minor repair. We only needed to go about 5 miles but there is 3-4 feet of fresh powder up there. It was quite warm but the weather was stunning. Yesterday I added a small bilge blower in an attempt to keep the carb cool and prevent the vapor locking. It helped but when I left it running to cut a downed tree it still stumbled and stalled twice after we were done cutting. But it was warm out and I had been driving up a steep hill with the throttle wide open for some time.
Not was, still is. We use it primarily for search and rescue. Or runs to the mountain top radio sites. Last winter I made four trips for radio repairs.
It came to us via the 1033 program. The Navy had it and surplussed it. We got it for free. It's a 1988 LMC1200. Had about 280 hours on it. About 350 now. It's in pretty nice shape for a 30 year old cat.
If it doesn't have one I'd put a electric fuel pump on
As close to the tank as you can and below it
Sometimes turning the heater on can help
looks like a good day and saved someone a few bucks by running them up.
did you bring the tree home?
jim
Just wondering, is there a chance you are seeing carb icing, not vapor lock? after a hard full throttle event you might have built up ice in the venturi.
Haven't tried the electric pump yet.
I left the tree there. Do you want it?
I have put my hand on the carb and it's hot to the touch. So I'm thinking vapor lock. But I like your theory.
I think a small piece of sheet steel mounted between the carb and manifold as a heat shield would help. My guess is fuel is boiling in the carb, as the radiant heat is heating the base and body of your carb.. Gasoline now days I fell boils at a lower point that the fuel of years ago. Maybe E10 is at fault here? I think it boils at a lower temp, due to the alcohol. Seems like I have seen this heat shield on a Thiokol at some point in the past few years.. Maybe here on the forum, I just don't remember, but I thought it was a factory deal. I have seen this set up on a 300 Ford in an industrial application, an enclosed trailer type air compressor.
I hope you find a cure for this gremlin in your machine.
I have fuel injection on my 1985 lmc 1200 It costs about a grand but no vapor lock and the cold starts are great plus the mileage improvement is nice!!
I have been giving serious thought to a TBI system. What is on your 1200 Bobby?
It is from a company called affordable fuel injection There top of the line kit even has a dodge diesel electronic throttle pedal Mine is regular pedal but the drivability is amazing
I have been looking at their website. Which system did you get? They have a legacy system and also several versions specifically for the 300 industrial. Was the install easy?
Niccce pics
I bought my 1200 from Ed out in colorodo I beleave he goes by mkntracks on here The hardest part would be welding the fitting for the o2 sensor
in the exhaust :clap:
"I have put my hand on the carb and it's hot to the touch." Yep, that pretty much eliminates carb icing as the culprit.
I like the heat shield idea. The other thing to look at is the fuel line routing. Make certain the fuel isn't boiling by the time it gets to the carb.
I have some pieces of aluminum to make a heat shield out of. Just haven't had the time.
This is what Bombardier put on my 1989 sv252g Skidozer Ford 300ci Industrial. Thin metal plate between the intake manifold and carb with insulation board attached. They even put it on the passenger side of the engine cowl to help with the heat. I believe this is what 300H&H is referring to. I would look into apiece of cement fiber board (used behind wood stoves) auger the center out enough to insert plate between carb and manifold for mounting. Note: also the fuel filter with the return line to tank that may help also. May also source some material from Mc Master Carr.
Today I brought in some tools from home and crafted a heat shield. I had some 6x12 plates of aluminum to work with. I used a hole saw, drill bits, hack saw and a file. The new base gasket is much thicker too. I had to get longer studs. I think it looks pretty good. Engine runs fine. I am hoping to try it out on Friday. We still have a lot of snow on the 70 road for a trip up to the meadows.
Well.... It didn't work as well as I had hoped. It was better but the heat was too much for my little bilge blower. It passed away about an hour into our trip.
Probably have that AFI system installed this summer.
As you can see the weather was awful. :wink:
Beats driving a desk.
Yeah and we had it all to ourselves. The groomer showed up around noon- 12:30ish and headed up. It was icy though. My driver had his hands full.
i have an sv 250 with a ford 300, i made a heat made of carbon fibre welding blanket. work great , no heat rising carb is cool.
