I've got a pool shed that is 75' away from the front corner my workshop. The rear corner is 100' away. I want to use a 3x-16x auto iris camera with 150' IR range to monitor the corner of the workshop that is 75' from the pool house. The camera is a brand new 700 TVL unit, Sony EFFIO chipset.
The problem is that I mounted the camera, focused, adjusted the zoom and during the day I get a perfect image. At night I get what looks like HEAVY FOG. The image is nearly WHITE, and I mean the entire monitor screen is virtually WHITE with almost zero contrast.
So I swapped the camera with another brand new, identical camera. Same result.
I put the camera INSIDE my workshop at night and tested it and the image was PERFECT with crisp black & white IR image, no IR hotspot, great contrast. I tested the camera in the back room of my cigar lounge (no windows) and got the same perfect results.
Re-mounted the camera under the eve of the pool shed, aimed it at the corner of the garage I want to monitor, and again the night image appears to be nearly all WHITE with almost no contrast.
So last night I rotated the camera to view my birdbath, measured the distance to be 22' away. Centered the birdbath in the screen and waited for nightfall. This time the image was NOT completely white, but it was about 65-70% WHITE with MODERATE contrast. I have a dozen less expensive cameras that give better images at night. But this camera, when tested inside, works perfectly.
What is going on? This is the second camera and I now have a 3rd replacement coming.
