Mini-Chain Saws - 6-8" Bars/1 hand operation
My S-I-L has some generic brand of one of the little tiny chain saws that is probably best described as one handed pruning saw. The thing works great. I've used it several times, it has some funky battery, not compatible with anything but the little saw works very well. Her's has an oil reservoir for 'bar & chain' oil. Its light. But it has managed to cut everything I've tried to cut with it.
For father's day my wife, knowing that I had been using her sister's little saw, bought me the RYOBI version of the mini chain saw.
The RYOBI variant is designed differently, it is much heaver but not a burden. First thing I noticed is you don't use bar & chain oil with this saw! Not sure how they do that. Ryobi uses a tool-less bar/chain adjustment knob, which is handy when you knock the chain off. I've done that twice in 3 days, but both times I'll admit that I was really pushing the little saw's abilities. And those abilities are considerably more than you might guess.
I've now used it for 3 days straight pruning back the paths through our trees. I put a 6amp/hour battery on the saw the first day. Big mistake. The saw is apparently very efficient, and I ran out of energy LONG before the battery was ready to give up. Yesterday I put a 3amp/hour battery on the saw and the battery and my stamina gave out right about the same time. Today I used a 4amp/hour battery and ran the little saw for well over an hour before knocking the chain off and deciding that was a good time to stop cutting.
I've been cutting some pine, some sumac, lots and lots of very hard hawthorn, some locust and a lot of unidentified scrub.
My main tractor path is about 100 yards long coming down a hill, it was about 15'-18' wide and over the past several years has seen mother nature narrow that to 10'-12' wide. So only using this little saw, I've reclaimed the full with. We have a grove of hawthorns and pines that I have now uncut to 8' so I can get under the branches with the tractor. Similarly a few other paths were widened and the low branches were cut up to allow the 8' roll cage to fit under the branches.
My observation is that YOU SHOULD GO TO THE STORE ANY BUY ONE.
I'm not advocating any brand.
Whatever brand your tool battery, buy that version.
But if you have woods and do lots of annual trimming, these things are awesome. Much easier than a little limbing saw. Much easier than an electric chain saw. Minimal vibration. Maximum convenience.
I have two versions of small chain saws. The RYOBI being one. The other is a small gas power STILH.
Personally, I prefer the Ryobi.
Electrics have come a long way and frankly my preference for work around the home.
I have a couple of the off-brand models. Love those little things. I do not have a problem with the chains falling off.
When I was cutting the tops off the posts from my recent pole building, I started with a gas chainsaw. What a mess and couldn't get a clean cut. Grabbed one of the little 6" saws and got nice clean cuts and it had no problem with the 4x6's.
What I like about the off-brands is most, if not all are pretty universal, especially the batteries. I bought a pole saw at auction for dirt cheap (the saw wasn't included). The pole, batteries, charger... all matched identically to my existing saws.
I have a Milwaukee 8". Love it. It seems to have more power than the Stihl normal/small electric saw I bought for $800+ with one battery and charger.
It's perfect for limbing and cutting stuff up to 4-5" and what is already on the ground but needs to be flattened.
I have the same one. The gas Stihls stay in the tool shed. The Milwaukee has a permanent ride in the back of my Kubota RTV.
  • Like
Reactions: Doc
A Milwaukee 18V Sawsall Used to be my favorite outdoor trimming tool but the little chain saw has it beat to pieces ! Much better balance and smoother and generally easier to control. I would use the Sawsall if I was cutting roots because the blades are cheaper but I rarely need to cut roots.
Honestly this is one of those tools I wish I had know about long ago.
I think it is going to be one of those tools that just stays on the tractor.
It fits nicely between the tractor seat and the fender. But I'd like to make a carrier/holster to make it a bit more secure.
  • Like
Reactions: Doc
I've had the Stihl pruning saw for about 3 years. It rides in the Kubota UTV with me. I love the thing. It comes with a little oil bottle. Before I use it, I squirt some oil around the bar and I'm ready to go. The only problem I've had with it is that my SIL kept borrowing it. Eventually I gave her one for Christmas and told her to keep her hands off mine. :giggle: Darn, that woman is rough on equipment. Every time she brought it back, I either had to sharpen the chain or buy a new one. I think she was using it as a trencher.
Agreed!
Another reason I prefer the Saws-All. Getting in the dirt for roots is best done with that tool.
Blades are cheap.
