Kitchen sink pipes blocked (I think)
p4evr
Hi all, new member here with a plumbing issue I am trying to figure out.
Scenario:
Started getting blocked over the months with poor flow and slow drainage.
I used drain, baking soda and vinegar with boiling water the week prior, no impact.
M used the small picks and brushes from Temo + Draino, and plunger a few days prior, now super blocked.
Run water it just stands in the sink and takes hours to drain.
Actions:
I took the trap out (very clean) and used pipe snake
- 1x with old 15' on that only when 10' due to previous damage.
- 2x with new 25' that reaches past the laundry drain down to sewer for sure.
No affect, now the bottom of drain leaks as all that drain snake maybe roughed up the connection?
Help:
I've done all that I can think of and thought to see what may have been missed or tried before calling in the pros. Hydro-jetting, cutting the basement pipe, clear whatever and re-assemble?
Your thoughts are appreciated. See pictures below showing piping from sink to the sewer line.
Sincerely,
p4evr
Have you confirmed the short pipe between the sink and the trap is clear?
Are any other drains in the house slow?
Do you have any air admittance valves on this line or under other sinks?
Are you on public sewer or septic?
Hi bczoom,
Yes, the short pipe between the sink and trap is totally clear. It unscrews as part of the trap and I looked at it 3 times and clean per the baking soda/vinegar last week.
Nothing else is slow, even the laundry sink which the kitchen pipes Y into before heading the sewer is fine. The washing machine runs pipe (straight down) fine as it feeds into the laundry pipes that go into the sewer pipe.
I do not have any valves under the kitchen line nor does any other sink.
I am on public sewer, of course I own the pipe to the property line somewhere underneath the house.
How are you thinking?
Sincerely,
p4evr
Here is a labeled picture of the basement pipes for clarity.
Thank you all for having a look, and have a fantastic day!
Sincerely,
p4evr
Are any of the other traps in the house or any toilets losing water? Meaning the system's vent is clogged and venting through the taps?
Crazy problem. Defies logic. Waybomb might be onto something.
I was going to guess a tree root was blocking the pipe but since nothing else is plugged we know that is not the issue.
If nothing else I'd be tempted to cut the long pipe before the vertical drop and run the snake forward from there. But before that get a 1 1/2 or 2" coupler and glue to put the pipe back together when done.
Okay. I had a similar issue. I tried drain cleaners, rodding the pipes, nothing seemed to permanently "fixed the trouble.
I bought an expensive gallon of some fancy super cleaner from Lowes everybody said would do the job. Nope!
Finally, I just bought a bottle of the cheapest generic Chorine Bleach and poured it down the sink drain.
BINGO!!!
Now I do that every three or four months. Drain is clean as a whistle!
The only thing this remedy won't clear is a collapsed pipe.
BTW, A garbage disposer grind things up but a horizontal drain ( Black Pipe) that is long and less than 1/4" per foot drop will allow sediment of the grindings. Do the Bleach flush every three months.
Thank you all for the feedback.
Yes, I will try bleach, and if that doesn't work, I will cut the pipe which was last resort.
Will let you guys know how it goes!
Sincerely,
p4evr
Sincerely,
p4evr
Hi all,
I did put a gallon of chlorine bleach from Walmart that took about 1/2 hr or so. Then ran water a few hours later, same results where the water backs up the drain after a few liters.
I'll try the auger again and hydro jet before cutting the pipes.
Sincerely,
p4evr
  • Like
Reactions: Doc
Maybe a pressure plunger would work. Most say they are for toilet but they also mention tough drain plugs. You'd have to remove the J trap to put it in I'd guess but maybe after everything else this would do the trick. Search amazon for lots of these type products.
Here is a link to one of the pressure plungers and a review from this one. I have never used one but I had read about them.
5.0 out of 5 stars Powerful and Easy to Use – Worth Every Penny!
Reviewed in the United States on May 27, 2025
Verified Purchase
I was desperate after trying every traditional plunger and chemical cleaner with no luck. This Pushare high-pressure air plunger saved the day! I had a stubborn toilet clog that wouldn’t budge, but after just two pumps with this tool—gone! The foot pump makes it super easy to build pressure, and you can feel the power when it blasts through the clog.
It’s really well made, and I love that it comes with multiple adapters for different drains, plus gloves so you’re not getting messy. Works great on sinks and showers too. This is a must-have tool in every home!
Noted, coax cable, not much pitch but is leveled downward, there could have been bacon/grease over the years as the pipes are 21 years old now, with lots of use.
Sincerely,
p4evr
..... there could have been bacon/grease over the years as the pipes are 21 years old now, with lots of use.
Before we bought our first house, (35 years ago), I assisted our landlord in removing a clog in the septic pipes outside the house.
......... DUDE!!!
I could NOT believe the amount of lard that accumulated in that pipe. There were two apartments in that house. Looked like EVERYONE was dumping their hamburger grease in the sink. I've grown to protect my pipes like a pitbull. Grease goes in a jar in the fridge and gets put in the trash on trash day.
That event changed me for life.
Same here. People were dumping food scraps, grease, small bits of paper down the drain. I had to remove the pipes from inside the wall where at a compound elbow joint a solid clog refused to budge or let a snake pierce through. No amount of force would budge it.
Now, I insist the drain trap strainers stay in place and catches everything. Yesterday the drain trap stainer was full of lettuce.
Thank goodness it was in the drain plug strainer.
And once a quarter, bleach.
“People” would not be me.
I clean the traps all the time. 😉
