freight sled
JimVT
I am planning to build a large aluminum freight sled and seen a couple on this forum but can't seem to locate them now.
Can anyone help me out?
Jim
Jim
What are you looking at hauling?
I built a sled that could haul any length lumber and whatever I wanted to stack on it.
[ame="http://www.youtube.com/watch?v=tl8MbtqVs6g&feature=youtube_gdata_player"]Freight sled - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=FCipSlstuJk&feature=youtube_gdata_player"]Pulling a load of lumber - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=NH9ZBrYxszk&feature=youtube_gdata_player"]Pulling the sled empty - YouTube[/ame]
f you want jum i will send you some pics of my little sled i loaned out an it was drug several miles accross dirt with several drums of fuel on it
Don
I remember when you built the one with the tracks. I need something that will fit in my pickup or on the trailer with my bombi or snow trac.
It would be for rescue type work.
Jim
Oh, I am going to a large 4x swap meet sunday.
you could modify the mesurements to make a freighter mine was made out of 1 inch steel and wood slats so snow could fall through it's runners were 1/4 inch by 6inch hdpe with 2x1 keels its a bit trashed after being running over 5 plus miles of barren ground i will shoot some photos of what was left the thing i liked was it would carry a load but was light enough to load my self when putting it in to the back of a truckthe runner supports were made from 6 inch hdpe pipe if i were to do it again i would use 10 inch pipe
Don
Jim
The sled I built could haul up to at least 2,000 pounds of lumber and supplies. When I built it, I made the ski stance the same as the snowmachine so that I didn't have to break trail twice. It is light and I used it behind both the snow machine and the Thiokol Imp. Here is some photos of it during the construction and a video of it carrying about 1,000 pounds of lumber (or more).
[ame="http://www.youtube.com/watch?v=1bfo_mbUGX0"]Hauling cabin building supplies - YouTube[/ame]
If your interested, you can either come see it or just use the idea of it to make your own. It has been replicated a number of times now by other guys wanting to haul freight.
I thought this might be interesting or amusing. During my build the wife walked by and I got some help.
I am having a little trouble with the swivel part but it's moving along.
jim
I found this video I did of my sled for other guys that are wanting to build one. This thing has about five years on it and has hauled a lot of building supplies out to remote locations for both myself and others. So it is looking a bit worn from the new shots, but still ready for work when the snow flies!
[ame="http://www.youtube.com/watch?v=qqtBLx4ygak"]Snowmachine freight sled - YouTube[/ame]
JimVT,
Don't foreget to post pics of the completed sled! Looks very good so far. I wish I had a spool gun for aluminum......
Best regards, Kirk
I got the hardest part done. A state wide snowmobile swap meet is this month and I plan on picking up some skis at it.
jim
Thanks Fogtender I will be able to finish mine now. You had explained it before but the pictures really help with the pivot detail. I am going to loose the springs before I go any further. Again grateful Kapkichi
My new sprockets showed up for the snow track so I been busy mounting them. i did fine some skis for mine and should be back at it in a few weeks.
jim
I wanted to get the main stuff first. Trimming will be done then . Like cutting off the frame next to the c clamp .
Your going to really like it once you start using it!
I put the wide ski skins on the skis which help float and allow the sled to Pull easier.
