opinions are like back sides, everyone has them.... I have a very low opinion of electric fans for many reasons.
If you want to invest in a worry-less situation. ditch that electric fan and build a shroud.
I am just not a fan of taxing the alternator with that Wattage. cats work hard and the only way to chase air out of the tunnel is forcing it along its path.....
I only charge $.02 for this unprovoked opinion..... and there is a $.05 rebate available.....
Also what I have been doing lately on rebuilds with blade configuration is I put a
Electric D03 block with 3 or more stations on the blade and get rid of the clunky
Mechanical valve bodies with all the hoses running everywhere and just run one
Pressure and one return to the blade via quick disconnects and install a electric joystick to control the valve bank now mounted on the blade. With its own disconnect. All hoses are short and outside. It’s so much cleaner and neater
That my 25 cent opinion same my brain only 25% still works most days![]()
Also, you bring up a good point about cooling air flow, I plan to extend the cab at some point, but the floor of the proposed cabin will close off the tunnel. Currently cooling air exhausts out of the aft engine panel (louvers in the panel) but adding an enclosed cabin shuts off the normal airflow.
How does the typical Thiokol-like cabin manage the cooling airflow out of the engine compartment - are there vents in the side of the tunnel? There are large square openings in the bottom of the tunnel on this cat, but I suspect those are blocked by snow as the cats rolls?
