WTB Tucker rear seat
pooreds
Looking for the original rear seat that came in my 1977 1344 Tucker. I'll even accept a picture of one so i'll know what to build.
the seats were built from plywood, just a plain 5/8 sheet cut to size, I can provide measurements if you need, pretty much the you can figure out the size from the configuration of the construction in the rear compartment, the covering was plain with no pleats and with about 1 to 1 and 1/2 thickness of padding.
did the bottom of the seat sit on a steel frame of some sort? did the back of the seat bolt to the same frame or did it bolt to the back of the cat? thanks
no the bottom seats just sat on the Skirting of the lower body and the back just screwed to the vertical framing between the rear windows
pretty sure you do a much better job and make it work for your needs
thanks for the pic, my set up is different, the back seat would be parallel with the front. my cab is not as long as yours. i think the seats would be exactly the same, just shorter. thanks again, i've only owned this rig for 2 months and the forum has helped a lot.
