Track jacks
snowcatt
I have a couple Bombardier Bombi's People mention Track jacks made with threaded rod Does any one know how they are made ? I would like to see a picture of one if possible . Straps work but not the best Thanks
sorry yes For installing tracks I put old steel tracks on my Bombi for the summer
Ratchet straps work but not well Im
open to and good idea's on how to make them
lots of track jacks on ebay.
I like the 300lb chain ratchets. light weight and use my track jack as backup.
on a bombi I think you could do it like a snow trac, the loosen the adjuster ,and pull the play out of the track with the starter and drive sprocket. than bolt them together between the front road wheel and sprocket
Here is a picture of how I did it---worked ok but flexed a bit under tension it provided lots of room to do the lap splice. If I do it again I will probably modify it to have a center slide reduce the deflection. it was pretty cheap to throw together. could probably get away with two all threads---it was nice to be able to align the two sides by tightening the individual nuts. good luck
