That's about $157.00 in today's money.When I was at the work cabin last summer I saw gold being sluced by water run off from my water tank and a spring at the property line with my neighbor. I put a shovel full in a bucket and brought it home, it’s very fine and flat but there is a lot of it in the sand, first I tried a blue bowl but if you turn the water flow up enough for it to work the gold went out with the sand, a little time on YouTube led me to the milling table design, was simple to make. I used chalkboard paint as recommended but the flat gold was still flowing out with the sand, it actually floats on the water without dish soap in the water to break the surface tension. Next I took 80 grit sand paper and sanded the bottom across the tray, that did the trick, now the sand flows out and leaves the gold behind, I can continue to experiment, but yesterday got a gram in a few hours. It’s slow but with gold approaching 5k an ounce I think it’s worth it.
That’s the beauty of the milling table, after you figure out the table angle and water flow, jut put some material in then go do somthing else for a couple hours, when you come back, brush what sand is behind where the gold has collected, turn the water off and suck it up with a snufffet bottle. I could make 10 or more miller tables and run them all at the same time easily.That's about $157.00 in today's money.
How many hours did you work panning?
Need any help doing more?![]()
Well I can’t be 100% sure until I smelt it and have it assayed, but it’s in an area with a history and lots of gold mines around me, the creek close by is gold run creek. When panned it’s much heavier than the blonde or black sand. The only other thing is pyrite and that is about the same weight as the sand so it should flow out with the sand. There will be some loss due to impurities when I smelt it, but I’m 99% sure it gold.Are you sure it's gold?
pThat's about $157.00 in today's money.
That figures approximately to the $157.oo I calculated.Today it’s $4454.48, but at the rate we are borrowing/ printing money, it won’t be long before it hits 10k
That's awesome. Do I detect a retirement project? Maybe a little sluce run going? I've been into all the gold mining shows on TV. I'd love to dabble in it but no clue where to get started.When I was at the work cabin last summer I saw gold being sluced by water run off from my water tank and a spring at the property line with my neighbor. I put a shovel full in a bucket and brought it home, it’s very fine and flat but there is a lot of it in the sand, first I tried a blue bowl but if you turn the water flow up enough for it to work the gold went out with the sand, a little time on YouTube led me to the milling table design, was simple to make. I used chalkboard paint as recommended but the flat gold was still flowing out with the sand, it actually floats on the water without dish soap in the water to break the surface tension. Next I took 80 grit sand paper and sanded the bottom across the tray, that did the trick, now the sand flows out and leaves the gold behind, I can continue to experiment, but yesterday got a gram in a few hours. It’s slow but with gold approaching 5k an ounce I think it’s worth it.
I just happened to see it on the mountain in little piles wherever the water was flowing, it kinda naturally sluced itself by the spring and the overflow on the water tank. The dirt has a lot of it in there but it’s flour fine and a lot of it is flat, lifts and flows out if the water is too fast or the angle of the pan is too steep. Good place to look is any streams out of the mountains that contain black sand, wherever there is black sand there is gold.That's awesome. Do I detect a retirement project? Maybe a little sluce run going? I've been into all the gold mining shows on TV. I'd love to dabble in it but no clue where to get started.
That is so cool!!
