So my mighty Ventrac lawn tractor, long out of production, is on its last wheels. Rear transaxle is toast. So it is now front wheel drive and can't climb a mild slope. At roughly 20 years old, it might not be worth repairing.
The Ventrac excelled where a traditional lawn tractor consistently failed. SLOPES. Because of the wide tires, 4 wheel drive and center articulated/oscillating design, the Ventrac was S_T_A_B_L_E on side slopes, could drive straight down and then back up ditch banks with ease, and just to show off, it could do 'figure 8s' on the side slope without any pucker factor of the operators hind quarters.
High on my list is one of the smaller POWER TRAC machines. Either the PT 180 or the slightly larger PT 422. Both are similar to the old Ventrac but use Hydraulics to drive the wheels. Neither are as compact as the Ventrac.
We have a John Deere/Toro/Stihl dealership less than 5 miles away. A Zero Turn Mower would probably mow faster, cost less, and some of them can manage the slopes I have. I know this because I had to hire a guy to mow. He uses a Toro and, he does say there is definitely 'pucker factor' on the steep slope.
The big advantage of the Power Trac is that I can get a lot of quick detach implements for it, at which point it could outwork my diesel tractor on a lot of tasks.
Power Trac Products
Compact Tractors, Slope Mowers, Articulated Tractors, Tractor Attachments, Trailer Packages
power-trac.com
H Class
power-trac.com
