This seems like BS ....but I'll share and hope someone try's it so we can verify it's BS or that it 'works. It would be cool if it works but I sure have my doubts.
Learned something new, thought I'd share because it's very interesting. It makes perfect sense I just never thought about this.
I love anything you could do naturally.
The navel:
Did you know why to put different oils in the navel?
Our navel (Nabhi) is an amazing gift given to us by our Creator. According to science, the first part created after conception is the belly button. After it is created, it attaches to the mother's placenta through the umbilical cord.
Our belly button is certainly an amazing thing! All of our veins are connected to our navel, which makes it the focal point of our body. Navel is life itself!
The "Pechoti" is behind the navel, which has more than 72,000 veins. The total amount of blood vessels we have in our body is equal to twice the circumference of the earth.
We knew that to lower the temperature for babies, we place a cotton hyssop with alcohol in the belly button, now we know that with oil, it's better.
Applying navel oil cures dry eyes, poor vision, pancreas, cracked heels and lips, keeps face glowing, hair healthier, for knee pain, chills, lethargy, joint pain and dry skin. .
Apply neem oil on your navel, to get rid of stubborn blackheads and acne
Apply almond oil on your navel, to help achieve a glowing face
Apply mustard oil on the navel to remove dry and chapped lips. It'll also keep your bowels moving to remove harmful bacteria, but it'll keep the good. It really works like a mild detox.
Apply olive or coconut oil to improve your fertility.
Keep cotton soaked in alcohol in your belly button to cure a cold, flu and runny nose. When a baby has stomach pain, we put a few drops directly into the belly button and massage it for a few minutes around the naval area, the pain heals. Oil works the same way.
Keep a cotton ball soaked in brandy in your belly button, to relieve menstrual pain and cramps
Sesame oil is used for all kinds of joint pain. Also known to strengthen bones. A lot of parents use on their kids every night at bedtime.
Use equal amount of mustard oil and ginger oil for stomach upset, bloating, nausea, and digestive problems.
Using warm oil improves blood flow to the nervous system and also improves the immune system. Heal constipation and build a strong digestive system. Relieves joint pain.
estr️Thyme oil is antispasmodic, helps relax arteries and veins, reducing blood pressure and stress in the heart. It can also help strengthen and tone the heart muscles.
As a diuretic, thyme oil can help your body remove excess water, salt and toxins from your body, which helps with weight, blood pressure, digestion and more.
un️Thyme oil is an expectorant, which means it can help remove mucus from the airways and lungs. Thyme oil is approved by the E-Commission of Germany in the treatment of bronchitis, whooping cough and inflammation of the upper respiratory tract.
Remember that thyme oil is a powerful compound and should not be used directly on your skin, as it can cause sensitivity and irritation. You should first dilute with a carrier oil (such as olive oil, coconut oil or almond oil)
100% Pure Therapeutic Grade Essential Oil is what you are looking for.
You can also put a cotton with CDS on the navel. This is for lowering fever, inflammation, gastritis, abdominal pain, etc.
* FOR KNEE PAIN * PARA
omAt night before going to bed, put 3 drops of castor oil on your navel and spread it 1 and a half inch around your navel.
*FOR PAIN RELIEF IN YOUR JOINTS AND DRY SKIN* *
At night before going to bed, put 3 drops of mustard oil on your navel and spread it 1 and a half inch around your navel.
WHY PUT OIL AROUND YOUR BELLY BUTTON?
Your belly button can detect which veins have dried up and by applying oil, those nerves open them up..
You can keep a small drip jar with the required oil next to your bedside and place a few drops on your navel before going to bed.
thanks Allyson Bordelon
The navel:
