Snowmaster #1656 rebuild
I’m wondering if any one has rotated the brake assembly by 180 degrees, and kept it from rotating by locating a tab (with an opening similar to that on the skid pan) to the (stiffener?) shelf that runs horizontally fore and aft above the axle. This will also require rotating and perhaps modifying the hand brake attach fitting, but little else unless I’ve missed something. Seems like a good solution if one wanted to eliminate the skid pan (to provide easier access to the oil drain plug, oil filter, etc. on the Subaru engine that will be installed. Let me know what you think.
My brakes (entire assembly) were missing when I got my st. I came up with my version of a disc brake system. They are held from rotating by a bar across the top that is mounted, with reinforcement, to the "shelf". works well enough for my purposes. I couldn't go down as the muffler and the brake disc are in the way.
As to the skid pan. The skid pan is not optional unless you only drive on hard pack. even with the skid pan my engine compartment has filled with snow and slush in a few circumstances.
Yes. I have hung an ej18 in- place of a 1776cc air cooled. I did it In a st4. My professional opinion is if the swedes had this motor readily available in 1958 they would have been in every anowtrac made.
I recently inquired with kennedy engine adapters for another flywheel and adapter ans was surprised to find a short lead time.
Brakes are over rated. I do like the disc brake conversions but hydraulic e brakes are not the best idea.
Hello, after several emergency ice fishing trips and a few trail rides, I’ve I bolted in the ej25 Subaru. Now I’m dealing with brakes. Is there any way to keep the VW drum brakes without major transaxle relocation? What disc brakes might work? Grateful for thoughts!
I'm struggling to understand why the own brakes need to be altered? Are they missing?
Many of my snow tracks have disc brakes. Some have non functioning drums one is a big wheel with inboard drums. Most all have functioning e brakes.
What is your current brake status?
There doesn’t appear to be room, either side to side or fore and aft. The brakes have been scrubbed up and in excellent shape and I was planning on keeping them pretty much as is but the ej25 Subaru is too wide to allow it. The right and left cams interfere even if the hand brake band is removed. If the whole transaxle could be slid aft by 1/2 - 1 inch that would solve it. I think that introduces all sorts of new problems and probably not feasible. Scratching my head over this one!
Many of my snow tracks have disc brakesl. Some have non functioning drums one is a big wheel with inboard drums. Most all have functioning e brakes.
Got it. I did a ej18.
Two longer chains.
One relocated rubber mount
Shift tower
Variator sheeves might clear
Steering box might be the biggest bitch
Too bad you dont have outboard brakes like the earlier small wheels had.
I removed the brakes (again!) and have the engine bolted in. To reinstall the brakes I had to pull the axles outward to allow the sprocket/brake drum on the axle. After assembly, and greasing the bearings, things went together snugly. There’s about 1/8” - 3/16” clearance between the hand brake band and the lower outboard timing belt cover. I’m hoping this will increase when I tension the drive chains but I suspect it won’t be significant. I’ve got the non-rotating part of the brakes inverted (180 deg, cast stub up) and restrained. I’m hoping all this will find some harmony as we move forward
Th
Thanks for the confirmation! It probably would be simpler to invent and build a Snotrac frame stretcher! At any rate, we will hope for the best !
I’m not one to give up easily, a blessing and a curse! With the brakes installed, with essentially no clearance between the hand brake band and the timing belt cover, I jacked up the front of the ej35 (rotating the engine vertically a small amount). This has provided about 1/4” clearance. Since the hand brake doesn’t move, in theory, I’m hoping it will work out. If it doesn’t, I’ll remove the hand brake bands entirely. (I haven’t had the heart to see what else has moved). If things seem ok I’ll keep the engine in place with an engine cradle mount. Comments, ideas? At least all front end bearings are repacked!!
Stay with me.
Add one or 1.5 links to the drive chains.
( Take a peak in the timing belt covers for your sanity... i bet there is another 1/8 or so in there ) loose the cover all together perhaps....
Go to the back of your rig. Slacken the track..... a lot....
Now. Go tension your longer drive chains. Carefully. Keep an eye on the bumper to sprocket clearance....
This should buy you the realestate that is bugging you.
Lastly tighten the track back up.
Shit while your at it stick some 15 tooth sprocets on your output so you can use some of that power!
You follow that?
Stay with me.
You follow that?
Follow? I’m w/you all the way. More later! Thanks👻
it would not be difficult to convert to outboard brakes - its all standard vw stuff - depends if your axle carriers have the lugs for the backplate.
If you wind up removing the drums from the driven sprocket, please take pictures of the drum for me. I'm recreating a braking system from scratch. When I got my cat there was nothing left of the original brakes at all I'm now wanting to try another version of home brew. Thanks,
Unfortunately the axle carriers don’t have a way to mount a backing plate. I think what I’ve got will work once I weld up a motor mount and get it in!
Dang it, it’s all back together! In the event I pull it all apart I certainly will take photos. It’s all pretty conventional, however, though drum brakes are a mechanical engineer’s way of punishing the rest of us!😬
I agree
re the skid pan, and plan on putting it back. I’m hoping that the rotation restraint I made will work. Remains to be seen!
I’m trying to figure out how posting works here. Please for give me if my replies don’t follow in sequence. Having a hard time finding your earlier response.
In your previous response you mentioned adding drive chain links. Where does one get ‘em? When I google it I’m sent to my micrometer and McMaster, Grainger, etc.
Also, the tracks are split and rolled up. I’ll bet there will be plenty of stretch in them so a link could likely be easily added. I did look at the output sprocket. Just looking at it, replacement looks like the whole engine/transaxle might have to come out. For me, probably best to let it go in peace!
try ebay. remember those chains are NOT SAE 80. They are metric 16B. same pitch, different width. 16B is wider.
Stay with me.
You
Stay with me.
You follow that?
I eyed the output sprockets. Replacement looks challenging, might involve a 10” hole saw unless the transaxle was removed. I’m interested in thoughts about the timing belt cover. It somehow doesn’t feel right to run without it. Thoughts? It likely would free up some space. Jacking the engine/trans axle (rotating vertically) seems to give enough clearance for now. I need to weld a motor mount to keep it in places. I also need to take a look for any problems created, so far it looks ok. Your comments are very helpful and appreciated.
16B links and half links are available at mcmaster car..
i buy them at a local farm store. Fleetfarm.
longer drive chain will get the large sprocket quite a bit further from the engine.
I ran high hp race engines with out covers.
The torc short course off road race engines belting systems are free air. Those engines were $60k. it was determined the covers caused more trouble than they prevented. My winter beater is an old S8 audi. It hasnt had the covers on in 12 of the last 20 years. 40 valves of god i hope that belt doesnt fail
All this sounds good to me. I have some 1/2 links coming. From the looks of things it should work out just fine. I took the floor jack out and still have daylight with the timing chain cover in place. If I need more daylight I could eliminate the hand brake band.
What’s your opinion on a motor mount? Seems like a lot of weight cantilevered on that VW bell housing, but then not a ton more than the bug motor that came out. I’m not planning on catching any air with this thing but know first hand where good intentions lead to.
Removing the handbrake may, depending on your terrain, not be advisable. I have had instances where it was REALLY needed. But I'm in mountains with steep terrain and not being able to set the brake would have produced bad results.
O
Oh Yes, I agree! Not a decision taken lightly. At least, very least, leaving it in gear would be an alternative. Our use for it will mostly on flat terrain and lakes but who knows! I had a PA 30 (Piper Pacer) that had a parking brake that operated by foot pedal. Pressurizing the brakes, then trapping the pressure by a hand valve worked great! That old pedal is around here somewhere! Not certain I’d want no way to park the thing!! Haven’t given up on the hand brake yet! Thanks for the good advice!!
That's the way mine work, I have switchable one way valves in the brake lines.
