300 H and H
Should the springs in the middle of the variator, that control sheeve clamping preasure and belt tension be preloaded at the same installed height? (these are dual nested springs in the pack) They are supposed to be staked to keep them in place? The upper set does the right hand sheeve set the bottom set does the right hand sheeve set....
This is when everything is centered, machine going straight. Mine are 0.15" apart, the drivers side (upper spring pack) being loose. When turning to the left this sheeve is opening and the belt is moving down into the sheeves, with less contact area than in the straight forward postition. Since the preasure from the spring pack for this side is loose, maybe this is why my machine is less agressive when turning left than when you are going right?
So with out changing the belt tensioning nuts, I tightened the lower pair of nuts under the dual spring pack to get it to the same installed height as the lower set, for the passenger side sheeves.
Did I do the right thing? It's not in the book at all, but seems to be very logical they should be equally compressed. And it may explain why my St wasn't turning as well to the left....
Thanks in advance, I do appreciate it!
Kirk
Kirk
