PineRidge
Back From the Dead
I am needing a member with a lathe willing to cut a hole in a schedule 80 PVC clean-out cap like the attached picture. All I need is the larger center hole cut for the rubber stopper, and it is important that the hole be centered and at the same angle as the rubber stopper taper (hence needing it done on a lathe). I am able to do the rest using a drill press. If you can assist please PM me.
