KT3survivor
Finally finished the dry sump conversion on my Kristi. It consists of a CB performance 2 stage oil pump, smaller diameter CB crank pully to accomodate the thicker pump, a one gallon tank from OBP, cooler block off plate, oil filter and external cooler from Empi along with two Spal 4" electric fans. Plumbed everything with -8AN braided line. I fabricated the cooler mount/fan shroud and a floor mount for the tank to prevent the system from draining back into the case. The cooler is mounted to the body vent keeping everything looking stock on the outside and everything has welded nuts on the backside for much easier removal/installation. The system now holds over 7 quarts of oil and will maintain pressure on a much steeper angle for longer periods of time versus the stock 2.5 quart wet sump.
KT-3's have a very low gear set and will climb + 100% grades no problem. now the oil system can keep up as long as needed on those angles.
