Inner sprocket bearing seal part #
utahwilson
Looks like I am missing the inner bearing seal behind the sprocket. Anyone know if this a standard part # that I can pick up at Napa? Manual part # looks like ST 1180. Top picture is without the seal (right side) Bottom picture (left side) has the seal. Thanks
Don't know about NAPA. If I need bearings, seals etc. I go to Applied they can find by dimension/use/cost. applied.com will get you local service center. They even had the lock washers for the rear pivot castle nuts.
Cidertom and JimVT thanks. Looks like bearing is part # SKF 6207. I pulled the seal off the left hand side and didn't see any markings. I was able to find the replacement bearing on applied.com. No seeing anything for the seal. Suggestions on what I would call this? Inner bearing race?
Thanks, Don, I have a local machine shop down the street. I will run down there as well and see what it would cost to fabricate. Might as well replace both since I am into it this far.
Did you get your seals done
I went through the seal deal..... That seal the hard black one ~ I got to thinking the tracks go 10mph and really that seal Im not sold works all that well so I went to a different seal. Just keep up on greasing out the water your going to get pitting in the hub regardless likely. Take a look at myKT7 thread there should be a photo or mention of the seal type and number. I will go look myself for you
