JimVT
Thought I would check with you guys  first before I start buying parts.
My bombi seems fine you can rev it up with no problems and it sounds great. But when you have a load or hit some deeper snow that puts a load on it looses power bad. It sounds like a miss . It only happens under load and at higher speed.
I removed the air filter and it didn't make any difference. Points have been removed and an ignitor 2 electronic ignition put in it. But It did the same with the stock points. When I had the points off I noticed some play in the distributor shaft .It was a very slight horizontal type movement only when I pushed on it. I wasn't sure if it was normal or not.
what I have is a 79 bombi with ford 4 cyl. 1600 engine with vacumn advance distributor.
any suggestions?
Jim
any suggestions?
Jim
