Dargo
Like a bad penny...
As would be my luck, I decided to go ahead and fix the ABS problem on my daughter's little Honda Civic with winter coming on and nothing went well. She actually doesn't get her license until just after the new year, but she needs to get used to driving the car and I figured having the ABS part of the brakes working would be helpful in the winter.
According to the code, all I need to replace is the driver's side rear ABS wheel sensor. That must be the favorite one to go out because nobody seems to have that one in stock and it costs more than any of the other ones. Anyway, as my luck goes, every single bolt broke off when I went to remove the sensor. Yeah, I sprayed, sprayed, sprayed and waited about 2 days before I finally put some muscle behind it. The end result is that every single freakin' bolt broke off. You know I wasn't getting that much torque using a 6 point 10mm 1/4" socket set to remove the sensor.
I have plans for the rest of the weekend, but with her car tying up one of my lifts, I need to get it fixed. What really sucks is not only do I have 6 broken bolts to get removed, but all but one of them are going to be tough to get to. So, I ask, does anyone here have any tricks that would be helpful? To be honest, the only bolts I've broken off before has been on heavy equipment and I've just welded a new bolt onto the broken one and removed it that way. This job looks like it's gonna suck!
