I was told the only differences between vehicular and utility is the governor curve.
I know nothing other than I have put highway equipment power plants on loaders ( usually Volvo ) and I have put loader / industrial equipment on the road. one m37 one 48 power wagon. I can't notice anything fueling wise other than the last loader I did has a fairly long lag to boost. I am thinking you will be very happy with your recipe...
yes, ive found the same myself. the exception is like some of the generator applications , with fixed gov., using an aux. electric motor to control the load. no fuel anaroid, etc..things like that. the good thing about the ''B'' series is that they are in a lot of applications, with multiple options of accessories, like the pump drive; p./s , vacuum, hyd. pumps for industrial units, etc... parts are fairly avail....
alittle prep work on t/c components... the adapter drive ring is ….3916222.... just a few pics to show the orientation to each other...
from the archives ….
brg. roll-in, inspect journals, mic, plasti-gage, rods & mains,(std.) torque, ck. free-roll, end play, etc...….
alittle fabrication today...
When you said a little fabrication, I thought you were describing how much it cost so far to the SO.
oh the fabrication for that hasn't begun yet. just meant I used some materials , laying around the shop ….. to be continued.... taking guesses on apparatus....
……. Allison AT545 first mock up....
buttoning up the 3.9L... pre-lubed the cyls…. test the injs…. install fuel system... adjust valve lashes... install the covers... flywheel housing...crank adapter (3906806)...flexplate….
……. removal of the old ''manual'' transmission mounts on the frame. due to the tight area of the ''intermediate'' driveshaft.... the pressed in studs on the transmission output drive flange are too long , to permit easy/quick removal of shaft. the input ''slip-yolk'' of the transfercase, only has a few inches of clearance , for this procedure...… the mounting bolts for the p/b anchor plate will need to be replaced , with the ''thin'' headed type bolts... so will adapt over to bolts , instead of studs...
I recently had to change the clutch and throw out bearing on a 318 in a 542CF. To disconnect the upper driveline, I drop both front and back drive lines, remove the transfer case mounting bolt except the lower back two and tilt the case back. Not so difficult. Maybe an option if your fix makes putting a wrench on both ends of the bolts a problem.
Good idea... I 'll fab it so I 'll only need one wrench. Up on the mountain....we would pull the engine to do a clutch...and leave the tranny in place.... Thx ?
Try that on a 542 CF. The engine has to come out through the passenger door if you are lucky.
The fun one is a BV206, has automatic tranny,but the engine and tranny needs to go through the door. Done the engine through the door several times on the Bombardier Muskegs
………… can t say that I know of any of those in our area...the swedes built some crazy stuff... they were used all around the world....built by volvo ??
They must have got the idea from Tucker. Build the cab around the drive train.
I had a fire engine that was built that way. The body builder welded the subframe around the chassis members trapping the pump. We wound up cutting the back out of the cab to perform what should have been a simple 1 hour repair.
I learned a thing or two about contract specifications ... a a few new words.
………. mocking up alignment of 4BT/AT545... a helpful trick ; to align t/c adapter ring mounting threads & flexplate holes for hardware, is to use a long stud , to line-up the first hole...
…….... tapped threads in output drive flange of AT545 … which secures the parking brake drum & intermediate driveshaft. drilled & tapped a ''locator'' bolt for p.b. drum to flange. reinstalled trans....removed 4BT from rotator stand. went for a F/D's ride …. found a few drags... notice rear tires removed for the season...
…. waiting for intermediate shaft from machine shop...
…… squeezed in sixty minutes today..... first mock fit of 4BT...
