Lyndon
This thread will cover the History, Operation & Maintenance of Snow Trac, Snow Master and Trac Master Variators in approximately 27 Chapters. So that you don't have to read thru the entire thing just to find out the answer to one question, each Chapter will be it's own Reply.
- History and Theory
- Daily User recomendations
- Belts
- 2 basic versions, Paddel & Spline.
- Thrust Berings
- Seals, Top,Side, Front, Rear & "caps"
- Bevel gears
- Pins & Dowels
- Ring Gear
- Starter Bushing
- 6 Volt Versus 12 Volt
- Linkage, Quick Shift Kits, Forks.
- Fluids
- Venting
- Tension Adjustment
- Sticky Splines
- 2 Adjustable Spring Assemblies.
- Special Adjusting Wrench
- Starter Ground
- Special starter mounting clamps
- H20 Damage (Water Damage)
- the 2 Spline Caps
- Where it's Metric and Where it's SAE
- Reassembly, Centering.
- Rig Steers to one side
- Parts interchangability
- Special Mounting hardware.
