anthonydoldd
That looks like it will work great! Did you keep it around the weight you were shooting for? Excellent workmanship, excited to see it when you get it all sheeted!!
Coming together nicely. Have you thought about it wanting to nose dive without the back cab on? I love the concept of it being removable though.![]()
I was thinking about steep downhill conditions where most of the weight is up front.
Awesome work! Can't wait to see it on snow.
i've got acrylic plexi c glass in my jeep for a side window that was missing in my acme door on the driveers sid eit's starting to frost up a bit now if i were to do it again i would use aircraft grade lexan it will last much longer and won't frost up in sunlight
go to glass shop and have them cut safety glass, cost is about the same as lexan or plexi glass, but you do it once and will not scratch very easy,
Nikson,
Looking good!! are you going to use any insulation in the cabs? I plan to use rboard or some thing similar. Should reinforce the aluminum to a small extent but noise and heat insulation will be nice.
Good work
Keep us posted!!
We tried the plexiglass once in a track loader. 8 months later pulled it out and the local glass shop used it for a template to cut safety glass. The plastic had gotten progressively worse to clean and see through.
I like what you're doing here! Nice! Can't wait to see the final product,.....
if there is such a thing as 'final' on any cat...![]()
Work in progress would work. Those doors look great. The radius corners are important to help them last.
so far looks pretty sweet...
