weatherby
oil pressure line
NO
oil pressure line
Anybody want to take a guess what was!!!.....it was not the valve cover nor was it the side cover gasket and this is on the pass. side of the motor![]()
oil pressure sending unit or oil filterI must say though.....I did have a minor problem which made me have to put away. after bringing it home one night I saw oil dripping on to the garage floor, after lifting the engine cover to check things out (and there was oil allover the pass. side of the motor) I could not for the longest time figure out ware all this oil was coming from because the radiator fan helped blow all the oil allover everything, so after checking all the most likely possible sources for an oil leak, I could not find it. Then after cleaning the oil off of everything I started the engine up to see if I could see any oil leaking from anywhere, and still nothing, no oil leaking from anywhere "UNTIL" I kept the engine at a high idle for about a couple of minutes then there it was. Anybody want to take a guess what was!!!.....it was not the valve cover nor was it the side cover gasket and this is on the pass. side of the motor![]()
one of the reasons to run an electric fuel pump with block off platenope, not the dipstick or sending unit......OK I'll tell what it was.....It was the fuel pump. The fuel pump has a weep hole and when you ran the rpm up engine oil started squirting out of the weep hole then the fan would blow it all over, but at idle it didn't leak. So I took the pump off and will take it back to get another new one, this one had 7hrs on it.
Yea, I heard that part in the video ... the most important thing is that she'll obviously be kept in mint-original concours condition unused after all the effort that Weatherby put into such a masterfully crafted piece of history and yet be enjoyed by a broader audience.
seems that the deal is not yet complete.... could go west at this point
someone has to dig deep yet.
That was mighty kind of Bobcat to send you his knob like that.
So this winter, when you're cruising around in the fields, every time you shift a gear, know that that's Bobcat's knob you're grabbing!
I just just spit out all my coffee on my key board! Thanks groomer dude. That was one of the funniest things yet on FF. Hope the key board doesnt start shorting out. e th once thyier kasldijui lwerhj ndsfai;dofhg;wojknaldfbgjkfbdvkuybfiuehgbiyuqhnenbiynogiuweobifgqrygvaiugvayfguyh
I forgot about that post....thanks!
YES....It takes every bit of two men to move them around. I remember seeing somebody on this forum using this style, and I thought it was you, but I searched all your threads and could not find the pic. so I thought maybe I dreamed it. Well its good to know you haven't had any issues with this style![]()
OK Boggie.....I could use your help. What I will need you to do is maybe create some kind of a distraction at the Mackinaw Bridge because there are always state police & motor carrier officers setting there watching for DOT infractions and any other odd looking vehicles pulling up to the toll booths. So what I was thinking....is maybe when you see me coming (across the bridge) you could get out of your truck and start video taping the bridge and that ALWAYS gets them excited now-a-days, and then when they all approach you or should I say (come running after you and tackle you) I can just roll rite through
Thanks DDS for your complements. Mainer...BigAl...I agree with you guys, I have been looking for a deck-over, I even sold my dump trailer to make room but I can't find one I like for a decent price. Then I got to thinking.........I think it was ether BobCat or SnowCatOpps. posted pics a wile back of a deck-over made by Utility Equipment, I saved all the pics of that trailer and I'm thinking of trying to get the measurements of that trailer and build one.
WEATHERBY,
What primer did you use on your parts before painting them?
I know the first painted parts will be the rims. I have seen the actual rims listed on some farm equipment site before. Still looking for them as Ive lost that link. I just need one more then I will have two spares. My grousers and backing plates are in excellent condition. How is that POR 15 holding up on the grousers?
so reading snowcat operations post it seams as the 601 went to live at a new location i just have a couple of questions when you started this project was your goal to sell it or use it? after rebuilding the 601 and getting to drive it was it what you expected? how many hours did you drive it?
