in retrospect, it was a lot of work, especially all the sanding. Most people are not aware that it’s all steel, even the end caps are stamped steel. No fiberglass anywhere. 42,000 lbs. of steelThat Wanderlodge paint job is in the 2% category. That is how many could pull off a job that size.
Good luck with that - I have one and still haven't finished it - very tricky build, much more difficult than the real thing!Stumbled upon this model ST4 from the UK. Had to order one, of course: https://www.scorpion-miniature-mode.../smm3544-aktiv-st4-snow-trac-civilian-version
I'm sure it is, his description of assembly looks tedious. I see he has a Wombat, and some other cool vehicles.Good luck with that - I have one and still haven't finished it - very tricky build, much more difficult than the real thing!
Yeah, the big muffler is my problem. I can lift it out upwards no problem, but once it’s in, the bic chain sprockets won’t go on because of the long axles, even with the brake discs off. Anyhow, so far I haven’t had to disassemble envy thing - yet. I think I’m going to put the drive chains on before putting the engine in, good access to then now. We shall see. Certainly easy to run wires etc. with the cab off.On mine, to remove the engine I have to remove the belly pan, the front end, the brake discs and as I pull the engine forward /drop/ it out the front. Not a whole lot of room any way you do it.
Put the transaxle in today after some preliminary wiring. New rubber flooring cut to size. I learned I have to install the big chain sprockets before I put the engine because i cant get them on with the engine in place Unless I remove the muffler which is a pain, so sprockets and axle housings go in. Next is engine then finish wiring the engine compartment and brakes before I install the cab.
Good idea, I'll check it.before you put the engine in, have a quick check with a straight edge that the variator belt is running parallel with the pulleys - mine was quite a bit out and was causing a lot of wear on the belt, the only way to correct it is to shim under whichever pulley is low - mine needed 4mm.
