Seems like I'm a bit skeptical of all these warning about volcanos. Sure, the scientists did get Mount St Helen's mostly correct, but I don't think their track record of predicting volcano eruptions is very accurate.
Still, this could be a viable warning and this could be a big one.
www.dailymail.co.uk
FULL STORY at the link above ^^^
Scientists warn massive US volcano could erupt in WEEKS
Scientists are on high alert after observing signs of unrest in a massive US volcano that sits just miles away from a city home to 300,000 people.
A giant volcano in Alaska is showing signs of an impending eruption.
Significantly elevated levels of volcanic gas emissions were recently observed around Mount Spurr, which is located 75 miles from Anchorage that is home to nearly 300,000 people.
The Alaska Volcano Observatory (AVO) said the emissions 'confirm' that new magma is flowing beneath the volcano, indicating an foreseeable eruption.
Increased seismic activity and ground deformation have also been detected in the surrounding area.
These signs indicate 'that an eruption is likely, but not certain, to occur within the next few weeks or months,' scientists said.
If Mount Spurr erupts, it would produce destructive mudslides, avalanches of hot gas and flows of lava racing down the volcano's side at over 200 miles per hour.
Scientists predict the ash cloud would travel hundreds of miles away, engulfing anyone in low-lying areas in toxic emissions.
'While we expect additional changes to monitoring data prior to an eruption, it is also possible that an eruption could occur with little or no additional warning,' they said.
Scientists warn Mount Spurr in Alaska could erupt within the next few weeks or months. It last erupted in 1992 (pictured)
'Over the last month, AVO has located over 100 earthquakes per week under Mount Spurr,' the team shared in a Wednesday bulletin.
'Most earthquakes are shallow (less than 2.5 miles below sea level). Magnitudes during this time are as large as M2.7. Over 3400 earthquakes have been located under the volcano since April 2024.'
The most recent signs were the increase of gas emissions, which reflect shifts in magma properties and activity beneath the volcano.
Sulfur dioxide levels were nine times higher than a detected in December, which led AVO to issue the bulletin.
Coordinating scientist David Fee told the Alaska Beacon: 'There was basically nothing coming out before, and now there’s a lot of gas, particularly CO2 coming out, which usually, when we’ve seen this at volcanoes in Alaska and across the world, it means that eruption is getting more likely.
Mount Spurr is one of 53 volcanoes in Alaska. It sits about 75 miles away from Anchorage that is home to 300,000 people
Scientists predicted the ash cloud would travel hundreds of miles away, engulfing anyone in low-lying areas in toxic emissions
Scientists believe the most likely scenario will be similar to explosive eruptions that occurred in 1953 and 1992.
The events lasted between three and seven hours, produced ash columns that rose more than 50,000 feet above sea level and deposited ashfall in south-central Alaska communities, according to the observatory.
These emanated from Crater Peak vent, about two miles south of the summit. The last eruption from the summit vent was more than 5,000 years ago. . . .
