Well, I'm done licking my COVID wounds and worked on the old cat some today, I drained the molasses and water mix from the pony gas tank. It got some extra time to work when I was down. First cleaned it thoroughly with water then acetone to get the last bit of water out. Also cleaned the fuel shut off and sediment bowl with acetone to cut some white pasty residue in it likely caused by ethanol fuel that dried. Next go I will check the tank for leaks one more time then paint it, then put the carburetor and magneto back on and the pony is ready to run again. I still have to remove the inspection cover on the main and check things out, clean the oil pickup if necessary then re fill with oil. I have to put about 5 gallons of gear oil in the main gear box add some water to the radiator and it will be ready for a go also. I have some other distractions going on right now like real work and I am also finishing up some work I am doing on my boat. I lost a month with COVID, but at least its not too hot anymore.
