New J5 size firefighter platform
MNoutdoors RIP
We had a need for non hydro mechanical drive small firefighter so we contracted a Canadian Company to build one. first one almost complete,to be used for wildland fire fighting.
86hp Perkins diesel
Allison 545
New differential using the T16
Basic Bombardier sprockets,tires,tracks
Joystick steering
Two seats
Stainless steel tanks
Picture is not complete, it was during testing full roll cage will be fitted tanks not on etc.
I like it !!
Can it tow a trailer with more water or chemicals ?
It can, it holds just over 100 gallons as viewed it has a 2" receiver hitch
But as with anything new it's not inexpensive comes in at around 80K the newer
Camoplast FF units came in at 102K but they are not building them anymore
Ready to start plumping the fire pump to the tanks a manifold will be placed in the bottom of the tub area as a sump area to be the lowest point for all angles it also adds a little water capacity
Old compared to new in size
The old one is functional Perkins diesel with 727 Chrysler auto built in 1989
It's also for sale with functional pump ready to work sprays brush good also stainless steel tanks 150 gallons total 10K
The unit is now complete, tested, and ready will post some pictures in the next few days we have received almost 7" of rain in the last couple of days and it has been hard to find a dry moment to get it out of the shop
Ps; one inch of rain equals 27,154 gallons of water per acre so 27,154x7 =190,078 gallons on one acre
Picture, built a basket for the extra hoses and suction hose for drafting, nozzles
Etc. still needs two fire shelters and fire extinguishers to be supplied by customer
That looks good. how much does it weigh? How fast can it travel on open ground or logging roads? is that hole in the roof the access for fueling the pump?
Speed if really needed to outrun a fire can approach 30 mph
Weight about 5800 pounds
Yes the hole is to fill the pump (good eye )
Really a nice looking machine... what is the suspension setup, you would want some nice stuff at 30 mph even with the nice suspension seats.
In the very rare instance you would need to go real fast to try to out run a fire
You would not have a real smooth ride. The only thing different in suspension is the front wheels are using AEON rubber springs
The back two remain the workhorse walking beams
Can you show a picture or tell which AEON you used and is it connected to the walker beam? I have my old 1964 in the garage doing different modifications and would like to see or know what you put under this machine. I have looked at some of the different suspensions they have, but not convinced it needed connected to the walker... your thoughts...?
The AEON is used on the front wheel where the old ones had a spring can
The newer ones used a torsion axle but they do not hold up.so the aeon spring was used,double convoluted rubber spring
The walking beams don't need springs.but a stop of some kind is good to keep from over pivoting
