Muffler information
rockaukum
1202B thiokol. Looking to replace the exhaust. Replaced the donut at the manifold to pipe and had to cut the exhaust pipe to get access to it. Looks to me like a hack job on the current exhaust so I'm gonna replace it. It currently dumps out in front of the rear differential and down towards the belting which can"t be good. Currently there is a one in two out can on it and I want to go with one in and one out. Any recommendations on which muffler to go with? I'd like something quiet if possible.
Thanks for any and all suggestions.
ra
I replaced mine with a cherry bomb style glass pack muffler it runs through the tunnel out to the very end of the bed . I got it on summit racing website , get a longer one if you go that route . mine is quiet ford 200 inline straight six.
Done!
Thought I'd come back with an update not he change out. I ordered a set of pipes that were pre-bent as a start. Once I got he sizes figured out and ordered the correct clamps (band style) I set off to work not he exhaust system. I decided not to pull the engine to replace the gasket to the head and settled on the doughnut on the down pipe. I cut the pipe jut front of the muffler and pulled the remainder out. Puzzled on hoe to run the exhaust out beyond the back of the cat, I reached out to Pat at sprite improvement for suggestions. Following his idea, I set out to finally get the job done. I think the pictures tell thee story on how I ran the pipe. the result looks clean but not quite as quiet as I had hoped but I'll live with it. The old can and pipe had little holes in it and I did not care of the one in and two out set up that was installed.
  • Like
Reactions: PJL
