MM 3 16s Plow
Not sure how many plow buffs around here, and I'm no expert myself, but I noted in the projects thread I just outfitted it with steel when I realized one of the rims was beyond repair, so thought I'd upload a picture here.
More or less, low-till around here, so I may not even find enough room to get it scoured up. However, thought I better have it ready in case the neighbor doesn't think his ducks-foot is enough load to break in that 22-36 he has over here.
If you do use that just be sure that the break away hitch is adjusted properly and working. Otherwise you may be histroy. You will need at least a 45-50 HP tractor to pull those in heavy sod or clay soil.
