It's dead Jim....
DaveNay
Klaatu barada nikto
I think it's dead.
238,542 miles.
Been consuming a lot of coolant lately.
Went to start it tonight, and it cranked about 1/4 turn, then stopped.
It won't budge. Starter engages and tries, but does nothing.
I believe it is spelled H-Y-D-R-O-L-O-C-K. :rolleyes:
Removed 5 of the 6 spark plugs. Broke the wrench on the sixth. I'm going to guess that's the one that is locked.
Next weekend I think I will be checking out the year end incentives on the 2006 F-150's.
Would you be referring to the pickup truck you used when you drove to Lowell to get your snowblower last year? Bummer.
Yep, that's the one. Bummer indeed.
DaveNay said:
It's been consuming a lot of coolant lately..
Partially melted bearings on the camshaft.. probably better if it won't crank over.
I had a jeep that ran for 5 minutes the morning after a day of 4X4 fun.. going over jumps etc... didn't know that a hole had been poked through the oil filter. Upon hearing wierd engine noise.. revving the engine doesn't help much either. :pat:
Nope..... it is just rusted in place because it is probably 100,000 miles since it was last removed.......:hide:
