So, If that got your attention, you most certainly know I am in need of some help.
Thiokol 1202B-38 is the model that I recently received. The previous owner had installed new gauges but they do not work. Hour meter and volt meter work but not the tach, oil pressure, fuel gauge, and water temp gauge. Today a friend stopped by to lend a hand. He is a electrician (mainly household stuff). We confirmed on the fuel tank that there is resistance and it changes when we lift the float. No shorts in the wires to the tank but the gauge does not work. We did the same to the oil sending unit and it too checks out okay but the gauge does not work. We tried trouble shooting the tachometer with no luck there either.
Anyone have any suggestions on where to start, what to look for? When I pulled the instrument panel off, I found three wires not connected. One hot and two not. I have not traced them down yet (waiting for the arrival of a tracer on order). There is power to all gauges, the lights work in the gauges but I think they have a separate power supply form the light switch.
I know I can operate the cat as is but....
I'd rather have this thing dialed in prior to heading out and about.
Any help will be appreciated greatly!
Pics are of the tachometer gauge, back of the gauge and the module mounted on the wall behind the gauge panel that the tachometer wire go to.
