How to Change the transmission oil in my Bombi
rustybarnard440
Can someone tell me how to change the transmission oil in my bombi. Its the standard 4 speed that comes stock in a bombardier bombi but i see no drain bolt. Can someone let me know how you drain it and how much it takes?
I sometimes take out bottom bolt on output housing then take off top cover and flush oil till comes out clean
The manual says the differential takes 7.5 U.S. quarts.
It also says to use Dexron II or Ford type F transmission fluid.
If you suck it out the top be very carful when you pull the cover off. I had a shift indent spring fall out and go to the bottom of the trans - very difficult to fish it out!
