Noises can be really hard to localize in a moving vehicle. I'd go to the u-joints first (front and rear).
2-3 shift could have a quick lock of the torque converter, exaggerating the clunk.
Hey doc - I do change my tranny fluid & filter every 25K miles. When it was new the first year, I did the first three changes every 10K, and didn't see much metal accumulation around the pan magnet after the third change and went to 25K service after that. It just seems to me if there is a filter installed, it occaisionally needs to be changed. Worked for me so far.
I got the truck with 130k on it. I didn't have the tranny checked until 160k, and by then the mechanic advised not to. It's wored so far (knock on wood). With the towing I do with it I hate to hear the "CLUNK".
Miles on truck? Speed at clunk? Under hard acceleration? Under light acceleration? Each time? Under load? Under no load? Has fluid and filter ever been changed? If so, when?
Doc, on hundreds of thousands of transmission failures the number one COF (cause of failure) can be attributed to fluid breakdown leading to hundreds of other symptoms. I work with some of the top techs in the business as well as the top techs from the manufacturers on Lemon Law cases and, except in cases of abuse, a surprisingly large percentage of transmission failures can be prevented by changing the fluid and filter a minimum of every 50k miles. If your fluid is that old, it likely is not providing much lubrication at all; only hydraulic functions.
As noted, I took the truck to the farthest point in my travels and went to add the Lucas stuff Dargo recommended.bczoom,
How is the truck running??
Well, I wasn't aware that it comes out like molasses. I clipped the top and started squeezing some out of the bottle. Apparently, it couldn't take the little I pumped in and it started coming back out and dropping on the exhaust manifold.
The smoke that came out reminded me of previous encounters (don't ask for details) with stuff dripping on the exhaust manifold. Expecting the ensuing fire I dropped the bottle, got the kids out of the truck and took off my Carhartt as it was the only thing I had to try to suppress the potential fire.
