Just sharing a recent frustration. I run up to my cabin twice a month, and while there lay hands on my Imp so she doesn't get too lonely waiting for white stuff.
And of course I fire her up just to keep things lubricated. The last few times she's taking a lot of cranking to fire up. I have an electric fuel pump in-line with the mechanical pump, that I'll run for a half a minute to fill the carb float bowl. Carb is rebuilt and accelerator pump is squirting gas, choke is set dependent on the ambient temperature....but too much cranking before she fires. Will fire and run fine instantly if I squirt in some starting fluid.
My guess is crap gas with a layer of water sitting on the bottom of the tank. There's only about 2.5 gallons of E10 in the tank and I suspect the alcohol has absorbed a bunch of water from the air. I did put Stabil in the tank last winter but I don't think that stuff guards against water absorption.
Thoughts? I'm thinking of draining most of the gas and refilling with high buck ethanol free 91 octane.
